Old 12-26-2018, 01:07 PM   #201
MontyPP's Avatar
Well we were getting ready to headout for a 4 night trip. I went to lower the roof... nothing happened :-( no buzz, grind or anything...
Unbolted the upper arm of the acuator (tight nut, rusted) went to unbolt the lower and broke the bolt at the attachment point :-( . Got it off and lowered the roof. I need a broom to raise and lower the roof anyways.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
2016 Nissan Frontier Crew Cab
Flagstaff T21TBHW
MontyPP is offline   Reply With Quote
Old 09-12-2019, 11:02 PM   #202
I have a 2016 214HW trailer that came with the electric roof actuator. I am now on my third one AND the unit is damnably hard to get up or down when the unit fails halfway!
Yes, the unit is under warranty but I don't have time for this crap on an otherwise great little trailer.
I have changed out the Forest River actuator for a Truck Camper lift jack and I doubt I will ever have a problem lifting the roof again...
I truly hope Forest River's other products are more reliable than their piece of junk roof actuator!?
bwa
bwallan is offline   Reply With Quote
Old 09-13-2019, 06:58 AM   #203
Originally Posted by bwallan View Post
.......I have changed out the Forest River actuator for a Truck Camper lift jack and I doubt I will ever have a problem lifting the roof again...
bwa
I went through 2 faulty FR actuators, both lasted approx. 1 yr. I am now using a homemade lift bar an RV shop installed along with two gas struts.
Could you please take some photos of where you installed your Truck Camper lift jack and how/where you installed it? Also a link to the product?
I looked it up and some have remotes....could you use one with yours?
Thanks in advance.
Furkids - Max & Tessa
2015 A194HW
2015 Ford Explorer
brewjaz is offline   Reply With Quote
Old 09-13-2019, 12:26 PM   #204
Thanks in advance.
The lift jack I installed is an hydraulic unit. I simply built a bracket to clamp a metal plate to the top of the jack. The plate has a hole that attaches to the bolt used by the FR actuator. The foot of the lift jack sits on a 16" higher wooden box. I store the jack and box in my truck box when it's not holding the trailer roof up.
I'll forward a picture next time I've got the jack in use.
The jack I'm using is:
https://www.riecotitan.com/camperjac...raulicjack.php
bwa
P.S.: A brand new FR electric lifter, provided under warranty, is stored with the remainder of my unused camping stuff. I doubt it will ever see the light of day!?
Old 09-16-2019, 01:38 PM   #205
bwa
Thanks--I'll keep an eye out for the picture of the jack in use.
2015 A194HW
2015 Ford Explorer
Old 09-17-2019, 08:22 AM   #206
bruc33ef's Avatar
Yes, but that jack is >$500. A replacement actuator is much less, although also less permanent. Gas struts would seem to be the cheapest fix.
2023 Geo Pro 19FD
2018 Kia Sorento 6cyl AWD
bruc33ef is offline   Reply With Quote
Old 09-17-2019, 11:25 AM   #207
Attached image shows hydraulic jack in use. The top mounting point is a flat metal plate welded to two 2" muffler clamps. A hole in the plate simply goes over the original attachment point of the FR lifter.
Pricing on this unit is all over the place. My RV dealership quoted me $750. Amazon was a bit better. My local NAPA dealer brought one in for $350 but it didn't come with a mounting kit (which I didn't require anyway). Used/rebuilt units are also available.
Optionally, look for a mechanical screw type truck camper jack. These come in motorized versions or manual. With a manual unit a power drill can be used to extend the unit.
bwa
Name:	Tent Trailer Hydraulic Jack.jpg
Old 09-17-2019, 11:41 AM   #208
OYO
Thumbs up
Works for me. If I had a working actuator I'd take it off and put gas springs on.
Easier, faster and durable.
OYO is offline   Reply With Quote
Old 09-17-2019, 01:25 PM   #209
bwa
Thank you so much for the info and photo. I'll keep for future reference.
2015 A194HW
2015 Ford Explorer
Old 09-17-2019, 07:24 PM   #210
Gramps42's Avatar
I think A-frame owners best recourse is a class action lawsuit asking for gas struts as a replacement for the OEM actuator
Roy
Gramps42 is offline   Reply With Quote
Old 09-18-2019, 06:07 AM   #211
OYO
Roy
I hear you. But you can get two 60 pounders for $60 and four brackets for $12.
Lawyers are pretty good at math.
Old 09-18-2019, 10:33 AM   #212
Gramps42's Avatar
Wow! Tell me where and I’ll order them instead of installing a new actuator
Old 09-18-2019, 02:04 PM   #213
OYO
http://www.forestriverforums.com/for...er-182535.html
The link to the Gas Springs in the initial post is to 40 lbs not 60s. I corrected it a few posts later.
Old 04-21-2020, 03:20 PM   #214
Has anyone found a replacement linear actuator for a 213hw other than from Rockwood?
Mine sounds like me getting out of bed and it's just a matter of time.
Casacarajo is offline   Reply With Quote
Old 04-21-2020, 04:20 PM   #215
Spike56's Avatar
Actuator
If you want the same OEM actuator, Forest River Rockwood is your only option unless you know the 'actual' OEM for the actuator - I do not. I rec'd my replacement very quickly and was a much better unit than came with our 212HW and worked great!
Spike56 is offline   Reply With Quote
Old 04-21-2020, 05:34 PM   #216
I had a Forest River A-Frame same issue. Found it was poor mfg of the actuator, dirt, grit and such got into the mechanism.
They replaced it for me for free but I did not use it.
I put on two more gas struts on the roof panel that had the actuator connected to.
Each was a 40 pound gas strut.
Took 1 hour to do each (you need a backer board inside for the screws will have something to connect to. I used decorative 4" squares like the old homes used to have at the upper corners of interior door trim. Looked great.
When through and I was ready to test the system installed, I unhooked the two clips/hooks (whatever they are called and the roof went up half way instantly.
Not so fast it scared me or that it might do harm. But it opened in 3 seconds and I could lift the roof system with my two hands using the roof handle that is on the passenger side rear side of the trailer.
Pulling it down (I'm only 5'-8'' and am 68) I built a 4 foot 1.5'' closet dowel with a hook on the end to grab the handle on the rear roof panel and it came down perfectly. I held it down and snapped the retainer devices and it was a done deal.
Go away from the ele actuator. It was a mistake in engineering .
Doc
DocHaley is offline   Reply With Quote
roo, roof
