Old 11-06-2012, 09:05 PM   #11
TRAVELINBOB's Avatar
Lots of diverse responses all have good common sense advice, think I will try using it but am now up to date on what to keep an eye on!
2016 BIGHORN 3760EL
2016 F150 SC ECO BOOST
2017 SUZUKI KINQQUAD 500 EPS
TRAVELINBOB is offline   Reply With Quote
Old 11-06-2012, 09:57 PM   #12
You have to wonder why the factory would put the grill bracket on the camper wall if it wasn't a good idea.
But then, my camper is worth well over 30 grand, do I really need to see for myself if it is actually safe?
Nope. Put it on the picnic table.
bakken is offline   Reply With Quote
Old 11-07-2012, 07:13 AM   #13
Those who do not own an Aframe do not understand the logistics of our little campers. Sure with larger campers you do have a windbreak .. but with ours there is little to none, as the back and front roofs slope at 45 degree angle. Add to this the window just above where the RVQ mounts, and if you have a the fantastic fan running it will suck the vapors/smoke right into the Aframe just as a previous Aframe poster reports.
Basically these little RVQ things hard to clean, flare up, and are just a poor idea. This is why you see so many Weber Q 100s and 120s sitting on the picnic tables.
D-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 11-07-2012, 07:17 AM   #14
lindy's Avatar
Easy way to clean your RVQ's is what I do 2-3 times a year, Easy-Off Oven Cleaner cold formula. Just spray the crap out of the grill and let set 2 hrs, then take a stiff brush to it and then rinse clean, gets 99% of grease off body of grill and 80% of burned on gunk on grill grate.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 11-07-2012, 07:24 AM   #15
TURBS's Avatar
D-mo
And again you can remove the grill you speak of along with the bracket and turn it into a table top version.
With that said I haven't had an issue with flare ups its a low pressure stove and doesn't really have a big flame.
I use mine a lot and wonder why so many people complain about them so much.
If anyone wants to give there's away I'll gladly take them off your hands .
Turbs
Old 11-07-2012, 08:15 PM   #16
ThunderRoad's Avatar
I haven't used mine yet - I can't figure out where to store it when not in use that is out of the way. :P
2012 Lincoln MKX
2013 Rockwood A122BH A-Frame
ThunderRoad is offline   Reply With Quote
Old 11-07-2012, 09:37 PM   #17
Originally Posted by thunderroad View Post
i haven't used mine yet - i can't figure out where to store it when not in use that is out of the way.
in the motor home! Duh! :>)
2016 BIGHORN 3760EL
Old 11-07-2012, 10:06 PM   #18
Jeep4Two's Avatar
My wife and I use ours for burgers and steaks regularly. We love it.
When traveling it goes in the back of the tv or in the rear storage compartment.
No heat issues for us. We'll continue using in future seasons.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 11-08-2012, 05:20 AM   #19
trudinator's Avatar
We don't live our lives by the "what if" mantra. we've used ours for 2 seasons now. No mess on the camper, the awning, and no problem with the decals. If the smoke is an issue with the fan on....turn it off before grilling. Seems like a no brainer.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 11-08-2012, 06:57 AM   #20
In today's sue happy society I would think that the manufacturer did testing to ensure the proper amount of distance (airgap) to prevent any damage to the sidewall. I haven't seen any reports of it causing damage, and I know there's a ton of them being used.
Len & Cheri is offline   Reply With Quote
