Hello Prairiegypsy,
I think I understand what your concern is...
your statement - (The leveler would partially slide onto the tire but was not wide enough to completely surround it).
I have experienced this trait too. As you raise the BAL Leveler, the tire will move towards the outside (away from the camper) on the BAL leveler and potentially overlap the edge of the leveler that holds the tire. The leveler is wide enough to accommodate the tire. What I do to compensate for the issue is to ensure that when initially placing the BAL under the tire, I position the tire more to the back side/inside of the BAL leveler. When it raises, the extra space between the outside of the tire and the outside of the BAL compensates for the sliding action. This has eliminated, at least for me, the issue and my tire does not hang over the outside of the BAL leveler anymore.
Was kind of hard to put this into words. Hope this helps.
Best regards,
Terry
Big Red Camper
"If you always do what you always did, you'll always get what you always got."
2014 Rockwood A128S
2015 Chevrolet Colorado Z71 Crew Cab 4X4 Short Bed
