Old 03-02-2017, 11:30 AM   #41
A small inverter to run the TV is a reasonable solution, too. Then you're only out the AC and microwave. However, get more batteries unless you'll only ever stay a short time.
aeblank is offline   Reply With Quote
Old 03-03-2017, 09:42 PM   #42
Lookin2camp's Avatar
Most of you guys are great helping this new RVer out! Thank you. The problem is the dough heads like Kimber45. You know some are using this forum for a good use, and ***** clowns like your self just need to shut it. I'd be happy to punk some of the dumb ***** you have said and spell too. Praying for many flats coming your way!
Lookin2camp is offline   Reply With Quote
Old 03-03-2017, 10:15 PM   #43
Who Dares, Wins
doc73's Avatar
Well that went an unexpected direction! Glad we could help though.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 03-03-2017, 10:34 PM   #44
Herk7769's Avatar
Originally Posted by spoonjps View Post
Ok so the dealership I bought my rockwood premier sucks. When I unhook to run on battery only the only things that work are outside lights and inside nightlight. Nothing else works. No Ac. No radio no microwave. Is there a switch or something to turn these things on.everything works when on shorepower
The radio should work on 12 volts, but not the TV(s) (which is 120 volt AC).
NONE of the duplex outlets will work (require 120 volt AC)
No Air Conditioning (requires 120 volts AC)
No Microwave (requires 120 volt AC)
No Converter (requires 120 volt AC to charge your battery)
Without shore power only these items will work:
Radio
Furnace
Fridge (on Propane)
Water Heater (on Propane)
Interior and Exterior Lights
Ceiling fan
Fantastic Vent
Tank Heaters
Propane detector
Slide outs
Landing gear/front jack
Stabilizers (if powered)
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
battery
