Originally Posted by spoonjps
Ok so the dealership I bought my rockwood premier sucks. When I unhook to run on battery only the only things that work are outside lights and inside nightlight. Nothing else works. No Ac. No radio no microwave. Is there a switch or something to turn these things on.everything works when on shorepower
The radio should work on 12 volts, but not the TV(s) (which is 120 volt AC).
NONE of the duplex outlets will work (require 120 volt AC)
No Air Conditioning (requires 120 volts AC)
No Microwave (requires 120 volt AC)
No Converter (requires 120 volt AC to charge your battery)
Without shore power only these items will work:
Radio
Furnace
Fridge (on Propane)
Water Heater (on Propane)
Interior and Exterior Lights
Ceiling fan
Fantastic Vent
Tank Heaters
Propane detector
Slide outs
Landing gear/front jack
Stabilizers (if powered)
