Old 12-26-2013, 04:10 PM   #1
OutAndAbout's Avatar
Battery & propane tanks location
Doe’s anybody know why they switched locations of the battery and propane tanks? And has anyone switched them back? It just doesn’t look right with the tanks further out on the hitch.
Never try to teach a pig to sing, it's a waste of time and annoys the hell out of the pig.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
OutAndAbout is offline   Reply With Quote
Old 12-26-2013, 05:21 PM   #2
Twisty's Avatar
Probably the manufacturer saving a few cents.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 12-27-2013, 07:20 AM   #3
Not only does it look peculiar, when you put a hard cover on the tanks, it gets in the way of operating the jack. I can see no practical reason for having the tanks in front. Only FR knows for sure. If you change yours, please let us know the cost.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 12-27-2013, 09:17 AM   #4
im thinking the reason the propane tanks and battery are in the front is a basic safety issue mandated by our transportation depts of the government. i would hate to see the carnage if some rear ended one of our trailers with them mounted on the back .. i know someone on this site has done that, im thinking just the batteries .. but will likely be pulled over by the troopers or police and given a ticket for that brilliant idea ..
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 12-27-2013, 09:47 AM   #5
Retread Popup Owner
Wojo's Avatar
d-mo
I believe the OP is speaking of the LP tanks being positioned in front of the battery.
On every camper I've had...and this is our fifth...the battery was mounted in front of the LP tanks. I'd be curious as to why FR chose to make the change.
2014 Flagstaff T12DDST A Frame
2015 Nissan Xterra
2015 Nissan Frontier
Camping Photos
Camper Mods
Wojo is offline   Reply With Quote
Old 12-27-2013, 10:00 AM   #6
My Roo19 has the tanks in front of the battery. I think most trailers are that way.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 12-27-2013, 10:47 AM   #7
KMP44's Avatar
Not sure how big the tongue is on the A-Frame, but on our Roo the battery is behind the tanks and the big advantage I see is that the tray was then long enough to hold 2 batteries without any modification.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 12-27-2013, 01:17 PM   #8
That may be why on the A-Frames too. Although new rails would need to be attached. because the stock rails are specifically fit for one small battery.
Tom
2012 Rockwood A122S
Old 12-27-2013, 03:37 PM   #9
Thanks everybody for your input.
Pooneil, your right about the hard cover and jack crank and the battery rails are to short for 2 batteries. If I change it I'll be sure to post picks and cost.
Thanks Wojo for clearing things up.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
Old 12-27-2013, 03:44 PM   #10
MtnGuy's Avatar
I had a Trailmanor with the propane tanks next to the jack. The jack was a front crank model. That seemed like a much better setup because I had 2 batteries behind the propane tanks between the frame rails right next the camper.
But there was a reason it was done like that on the Trailmanor.........if the propane tanks were next to the trailer it would not allow enough room for the front clam shell to open.
battery, cat, location, propane, tank
