Old 04-24-2015, 08:11 PM   #1
A-Frame Don's Avatar
Battery Disconnect
What would be the most convenient way to disconnect the 12v rv battery when unit is parked. I see online there are many different products for this purpose. I did buy a pull/push switch from my dealer and he said to wire it with the converter under the dinette bench. Maybe I could place it in a more convenient location with longer wires. I'm thinking in the front storage trunk. My previous Coleman TT had a plug on the tongue you just had to pull apart, very convenient.
A-Frame Don is offline   Reply With Quote
Old 04-24-2015, 08:22 PM   #2
Shinny's Avatar
I use an RV/Marine battery shut-off switch
2015 Sierra 32QBBS-23 nights camped since the end of June 2014
2015-sorry to say only 11 nights so far, more to come though
Shinny is offline   Reply With Quote
Old 04-24-2015, 08:26 PM   #3
Canadian Member
itat's Avatar
The most convenient would be to have the switch located near the batteries so you don't have to go inside to turn it on-off. I mounted a Blue Sea waterproof switch under the propane tanks on my previous Roo hybrid. Some mount them on the side or top of the battery box.
If you already have a pull/push switch and it's not waterproof, I'd look for a location near the power panel. Put the switch in the +ve line between the battery and the power panel.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 04-24-2015, 08:28 PM   #4
RedLdr1's Avatar
I'm looking for a good disconnect system as well. Right now I just disconnect the ground wire from the battery, not very elegant, or convenient, but effective. In my case the disconnect needs to be outside of the main unit so I can use the power roof lift.
I'm probably going to go with one of the big plastic rotary switches. Putting it inside the cargo box is a very good idea. My previous experience with these type units has not been good when they are left outside exposed to the weather.
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 04-24-2015, 09:16 PM   #5
Blackhat6mike's Avatar
Bat Switch
Go to any marine store for the on/off/bat 1/bat 2/both switch. If you only have one bat, a simple on/off switch will do. Buy enough cable to mount the switch where ever you want it, or install it in line with the current bat cable. The shorter the distance from the bats is better. All West Marine stores have either of the two switches or Amazon.com.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 04-24-2015, 09:43 PM   #6
On ours we just pull the fuse located near the battery; 25 amp fuse.
toxophilus is offline   Reply With Quote
Old 04-25-2015, 09:17 AM   #7
RedLdr1's Avatar
I don't think that will totally disconnect the battery. On newer trailers the CO2 detector is usually hardwired to the battery. It will continue to run down your battery unless you install a disconnect of some type.
Wayne and Christine
Old 04-25-2015, 06:15 PM   #8
Now matter how you disconnect the battery. Make sure the breakaway switch is powered when you are driving so the brakes will activate if needed.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 04-25-2015, 06:41 PM   #9
Timex's Avatar
Mounted mine in the nose compartment of my Vlite. Got it from Amazon and a 4' auto battery cable(4 gauge) from Auto Zone.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 04-25-2015, 07:09 PM   #10
GreenImp's Avatar
Send a message via MSN to GreenImp
Another option is to use Blue Sea Systems 187 series circuit breakers. They are rated to be used as a switch, are waterproof and ignition protected (won't ignite gas due to spark). All that and you get the added benefit of circuit protection. You can find the Blue Seas 187 series under the Bussman brand name for less cost, but I can't remember what they called them.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
battery, battery disconnect
