Old 09-11-2018, 02:41 PM   #41
ColoradoRick's Avatar
We have the internal cut-off switch inside the Rocky BUT did have a big lessons learned last year.
We had Rocky parked for a few weeks between trips and when I went to pick her up at the lot the batteries were graveyard dead!
The kill switch was off and I confirmed nothing was powered on inside the camper. The only things that will work with the cutoff turned off are the outside power levelers and the front motorized tongue jack. I doubt anybody had been messing with the levelers so I looked at the tongue jack. The tiny nighttime light switch was on...so that little light was burning for 3 weeks and eventually killed the batteries....it was amazing!
Now, I always make sure the switch is OFF when I park Rocky....I may just end up removing the light or taping the light switch to the off position.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 09-11-2018, 03:08 PM   #42
I have everything get turned off with the disconnect switch except solar controller. Solar is on the battery side of the disconnect so that solar can't power the trailer with the battery disconnect off.
2017 Coachmen 233RBS
2018 Ford F150 Lariat
"Common sense is not very common"
babock is offline   Reply With Quote
Old 09-11-2018, 03:30 PM   #43
Herk7769's Avatar
Originally Posted by CUBS_WIN View Post
So the one with the cleaner Interstate batteries is correct?...lol. And the ground wire is the black one on the bottom of the picture?
Yes
Here our old setup Ö
The wire out the top goes to the Inverter.
HAM CALLSIGN - KC3FFW
Old 09-12-2018, 02:11 PM   #44
What wires do I want to disconnect from my battery to cut the power to them. Just donít wanna drain my batteries while Iím waiting for my disconnect switch to arrive that I ordered. Itís a 2 battery setup hooked up parallel.
CUBS_WIN is offline   Reply With Quote
Old 09-12-2018, 02:34 PM   #45
Herk7769's Avatar
Ground wires on the battery that goes to the frame will usually do it.
Both positive and negative will make sure you have it all.
Touching a volt meter from either positive to the frame should show no voltage. If you see more than 10 volts between the battery and the frame, it is not totally disconnected.
Old 09-12-2018, 02:37 PM   #46
Old 09-14-2018, 08:37 AM   #47
I got my battery disconnect switch yesterday. I just need to know what wire on on the input post and what wire goes on the output post. Click image for larger version
Old 09-14-2018, 08:39 AM   #48
I have the dual battery setup on my travel trailer and they are hooked up in parallel.
Old 09-14-2018, 08:52 AM   #49
personally it shouldn't make a difference as all you are doing is interrupting or completing a circuit. but the picture is interesting in that it has the word 'input' on one terminal. also, it may just be the angle of the photo but it looks as if the two terminals may be a different size. were there any instructions with the switch? if not i don't think it matters.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 09-14-2018, 08:54 AM   #50
I prefer putting the switch in the positive, but either side will work.
Output is the wire(s) coming to the battery post from the trailer.
Input is a new wire from the battery post to the switch. See your automotive parts store for a battery cable of the right length and end fittings.
Using the switch to disconnect the camper from the batteries is great. However, the switch you are using does not take the batteries out of parallel. If you need to take them out of parallel, you will have to do it by unhooking the parallel cables (or cutting them in an emergency).
Hope this helps.
Fred W
battery, battery disconnect, switch
