Originally Posted by w101ttd
Hi Everyone,
The battery was dead. It was charged all night. Now it is at 12.56V. there is an-in-line fuse holder without fuse. from the manual, i think it is a 25A fuse. I bought a new fuse, tried to install it in the holder. It was busted even before I could finish pushing it in! It kinda freaked me out since i know nothing about this stuff. Please help! Thank you so much!
Between the converter (assuming a WFCO 8735 converter) and the battery there is (or should be):
- a 30 amp fuse in the converter fuse panel. This is the fuse for the battery circuit.
- a 40 amp fuse in the converter fuse panel (blows if the battery is hooked up with reversed polarity). Protects the converter.
- a circuit breaker that can be reset with a tiny button on the case, located in the wiring under the frame or along the tongue.
- some dealers add an in-line fuse near the battery terminals as a poor man's disconnect. Can be spade or tube type fuse. Should be 30 amps.
Chances are if the battery has been significantly discharged, and left that way, it's voltage will drop very quickly under any kind of load. It should be load checked, and if need be, replaced.
It's hard to say what is causing the replacement fuse to blow other than a short circuit. Where that short is, I can't tell you without examining things and checking with a voltmeter.
I would disconnect the battery, and start at the converter (camper has to be plugged in for this). Make sure all the fuses in the panel are good, and that everything 12V works. Next check voltages at the battery leads with battery disconnected (should be 13.7V). Then, and only then, when everything else is good, reconnect the battery, making sure the polarity is right.
just my thoughts and experiences
Fred W
then: 2014 Rockwood A122 A-frame
now: 2019 Flagstaff T21TBHW A-frame
