Old 10-25-2013, 06:15 PM   #1
Battery removal A122
Hi I have a simple question and have searched the answer to no avail.
How do I remove my A122 battery for the Winter (take hot connection off before neutral, the other way around or does it not matter?)?
I also heard that I need to keep my battery charged through the Winter, how do I simply do this this (I do not own a trickle charger)?
Thank you!
Bend5729 is offline   Reply With Quote
Old 10-25-2013, 06:29 PM   #2
Ford Idaho's Avatar
I do the ground first, then the positive.
Battery MINDer | 12v 1.5 Amp Battery Charger, Maintainer, & Conditioner
Old 10-25-2013, 06:44 PM   #3
Mostly Harmless
thehamguy1's Avatar
Originally Posted by Ford Idaho View Post
I do it the same way. I use a Battery Tender Jr., rather than a Battery Minder as Ford Idaho does, but I doubt it makes a difference which one. The BT Jr is about $23 on Amazon. The battery is stored in the garage while the BT is connected. Using a BT of some kind all winter keeps the it charged and prevents sulfating, a big killer of lead-acid batteries.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 10-25-2013, 06:57 PM   #4
Ford Idaho's Avatar
Originally Posted by thehamguy1 View Post
I do it the same way. Most auto manuals recommend disconnecting the negative first so that's why I do it that way, though not sure why it would make a difference. I use a Battery Tender Jr., rather than a Battery Minder as Ford Idaho does, but I doubt it makes a difference which one. The BT Jr costs over $30; maybe the BM is more reasonable. The battery is removed from the camper and stored in the garage while the BT Jr. is connected. My battery life has been greatly extended by using my BT Jr. all winter. Keeps the battery fully charged and prevents sulfating, a big killer of lead-acid batteries.
I bought that because I plan on installing at least one more battery three would be better but real spendy, the battery minder will handle up to four.
Old 10-25-2013, 06:58 PM   #5
Mostly Harmless
thehamguy1's Avatar
Yeah, I think the BT Jr can handle just the one batt.
2011 Rockwood A128
60W solar system
Old 10-26-2013, 11:12 AM   #6
MountainGoat's Avatar
Perhaps this is a naive newbie question, but I am curious. Is there any downside to simply leaving the camper connected to shore power in the winter in order to keep the battery charged? The only thing I can see is that I won't get the de-sulfating benefit.
Similarly, I am considering leaving it set up in my driveway for use as a guest room in the winter. It's already winterized, so no worries about freezing. It can snow a bit here, but it doesn't appear that snow load should be an issue, between the pitch of the roof and the structural design. Any opinions or experience with this?
Dan Kucera
KDWJO
2014 Rockwood A122S
1995 Toyota Land Cruiser
MountainGoat is offline   Reply With Quote
Old 10-26-2013, 11:17 AM   #7
Ford Idaho's Avatar
Not yet!
The old camper I had never leaked any that I could find.
This is my first winter with this trailer so I will keep a sharp eye out for leaks and then take it to the dealer if need be.
Old 10-30-2013, 06:19 AM   #8
Newbee
The reason that the neg should be DCed first.... If in the process of disconnecting the first post, the wrench should touch a metal surface - the surface would be naturally be grounded. A circuit through the wrench ground (at the neg post) to ground (on camper metal) would cause no arc... Conversely, a circuit through the wrench POSITIVE (at the battery positive post) to ground ( camper body metal) would result in a dead short acctroo the full battery!!! Over a hundred amps!!! Severe burns when the arc flash occurred... Burns from the red hot wrench... Possible acid burns from an exploding battery!!! Yup, I would disco the neg first!!!
BuckeyeJeeper is offline   Reply With Quote
Old 10-30-2013, 10:00 AM   #9
Welcome to the forum, BuckeyeJeeper.
Let me add that when disconnecting a battery, make sure to move the wire away from the terminal so it can't fall back on it and inadvertently reestablish the connection. That can lead to an unpleasantly negative surprise.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 11-01-2013, 08:51 AM   #10
Thank you for the replies. I just took the battery off of the trailer without a problem. When connecting it up again in Spring should I connect the positive side first?
a122, battery
