Old 11-27-2013, 06:58 AM   #1
Battery Storage Location
Has anyone tried moving the batteries off the tongue to the front storage area? If so what problems did you encounter? Can it be set up so you can run wiring for Solar Panels and a battery tender? I am getting close to ordering/getting my T12DDST. Just don't like the idea of exposed batteries or chintzy battery boxes.
dts3204 is offline   Reply With Quote
Old 11-27-2013, 07:27 AM   #2
Ford Idaho's Avatar
Why not just upgrade the box?
https://www.google.com/search?newwin...65.zDVblhWiJQg
Old 11-27-2013, 08:02 AM   #3
Old Enough to Know Better
gasman6674's Avatar
You will need to vent the storage area or mount a box inside and vent that.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 11-27-2013, 08:35 AM   #4
National Park
I'm with Ford Idaho on this one. I have a A122TH and while I have a big platform I could locate batteries to, it seems more logical for my needs to leave them in the same location and upgrade the box they are stored in.
Have fun ordering your camper!
Ron and Kelly
2014 Rockwood A112TH
2004 Toyota 4Runner V8
Always Exploring
Canyonlands is offline   Reply With Quote
Old 11-27-2013, 09:17 AM   #5
mark0224's Avatar
Looking for an idea for adding an extra battery to a v lite, there isn't enough room to add an extra battery. Wish they had made them in the propane compartment.
mark0224 is offline   Reply With Quote
Old 11-27-2013, 10:07 AM   #6
Ford Idaho's Avatar
How about a rack to put one over the top of the one you have?
Old 11-27-2013, 11:33 AM   #7
Your storage trunk has a manufacturers stated capacity of 150 lbs, which is supposed to be spread over the entire trunk. Depending on the reason for that rating, exceeding the weight may or may not be a problem if you are relocating the battery. If the reason is tongue weight, then relocating will not over burden the tongue.
OTOH, if the reason is not to over burden the middle of the frame, then you would have to be very careful how much other weight you put in there after dropping in 50-80 lbs of battery.
But not knowing the reason for the rating, everything here is speculation. So call FR to consult with them before putting a battery in the trunk.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 11-27-2013, 12:35 PM   #8
Got my answer thanks to everyone for responding.
battery, cat, location, storage
