Old 06-24-2013, 09:14 PM   #1
elmonsanto's Avatar
bent stabilizing jack screw
One of my A122S stabilizing jacks has a bent screw. It makes it difficult to hold on to the Black & Decker drill I use for raising and lowing the jack. Doe anyone know of an easy way to straighten the screw? Can anyone recommend a good replacement jack that doesn't require me to drill new holes in the frame? Thanks!
Laurel & Lynn (amateur radio W6JAE)
Felix & Cleo (retired greyhounds)
2006 Toyota RAV4
2013 Rockwood A122S
elmonsanto is offline   Reply With Quote
Old 06-24-2013, 09:22 PM   #2
You should be able to drive out the roll pin in the screw and remove it and straighten it on an arbor press or very carefully in a vise if you protect the threads with wood, etc and get a long pc of pipe and carefully bend it back straight. Then just reverse the procedure putting it back together.
