01-29-2018, 09:36 PM
best approach for changing tires on same wheels?
i am a bit overdue to replace the OeM tires, which have not given me any problems to date, over to a newer manufactured tire.
this question is not so much about what tires to get as replacements - i see there are plenty of threads about this.
i am more wondering the best and most efficient approach to get the old tires off the wheels and the new tires onto them.
dealer is a bit too far away to go to for this...
will a regular auto tire store perform this service? if so, do you bring the whole camper to them or take the wheels off the camper and just bring them the wheels?
if you remove the wheels, what is the best way to do this? put the camper on blocks or...?
there are a few lawnmower/tractor type places around where i live that sells some of the popular tire replacement brands, are they a better choice due to familiarity with trailers and trailer tires?
for the big rigs watching this forum, this is a post about a lightweight A frame travel trailer do not the same process probably as the big truck tires the larger rigs may use.
seeking any advice or experiences.
R
2011 A-122
01-29-2018, 10:00 PM
Scoundrel
I brought my old pop-up to a local tire store and they replaced my 13" tires with new. Or just pull the wheels and do the same.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
01-29-2018, 10:07 PM
Scoundrel
Sorry - I didn't answer all your questions. You can jack the camper up and put on jack stands under the leaf springs, pull the wheels off and bring them to any decent tire store and replace the tires. Or hitch up and bring the A-frame to the shop and they'll do it.
I would call ahead first and be sure they have 13" trailer tires in stock and can get you in.
Good Luck
01-29-2018, 10:45 PM
check out wheels and tires on rims at etrailer dot com many options
sometimes buying the whole tire and rim is not that much more expensive then buying a tire and having it put on the old rim...
2014 Shamrock 183
01-30-2018, 04:53 AM
I just replaced my tires. I used the tools I had to see if I needed anything else for a roadside tire change to pull the wheels, then left the trailer on jack stands. I have a auto shop where I changed the tires myself, then took the wheels back and put them back on.
I used a bottle jack on the frame right next to the axel to jack it up, then put a jack stand under the same spot.
I don’t think you will have any problems doing it any way, just call the place beforehand and talk to them.
01-30-2018, 06:38 AM
If You know the Proper location to Lift/Jack Your unit and have the proper tools and blockage/stands for Safety, remove the tires yourself! If you take it to a "Tire Shop" you will be at their Discretion on how They want to "Jack it Up"! Nine times out of Ten they will use the Axle! Youroo!!
01-30-2018, 07:08 AM
Good thread. I've been mulling this over myself.
I see two conflicting suggestions here. Block under leaf springs. Block under frame.
I doubt your Aframe has leaf springs, it probably for sure has torsion springs.
Block under frame is the right answer. And never under the axel.
01-30-2018, 06:09 PM
If the locals sell tires and mount tires, take the trailer to them, its no big deal. If they don't want to work on it, they'll tell you.
If you are thinking about changing them yourself, Harbor Freight sells a manual tire changer. I bought one to switch tires on my utility trailer and was surprised how well it worked. The price was easy also at $42.99. It is a good idea to change the valve stems while you have the tire off the rim.
01-30-2018, 06:27 PM
X2, or watch them when they jack it and make sure they know what they are doing. In the last year 1 of 3 shops was about to jack ours on the axle, had to tell the kid to stop and then he went and got an older guy who showed him where to put the jack...
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
01-30-2018, 07:33 PM
I agree with RSDATA's comment. I had to purchase tires last year for my trailer because of a blow out on our way to a park. Because of the location, I had to buy from a tire shop. I was going to buy only one to replace the blow out but ended up buying 2 after checking the date of manufacture on both tires.
After getting home I checked around on-line and found I could have bought new tires with wheels from a couple of well know websites for basically the same price and installed them myself.
01-30-2018, 07:41 PM
Just a word of caution. Check your wheels for any stickers that indicate they are directional. Mine had these stickers. Looked my wheels over closely, and could see no difference between the wheels from the left side vs the right side. BUT, why tempt fate. I made sure, when I got new tires, the wheels from the left side went back on the left side, and ditto for the right.
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
01-30-2018, 08:00 PM
However you end up changing the tires , make sure you have them balanced.
H.
01-31-2018, 12:01 AM
H.
Yes, why do they even ask? Get 'em balanced.
Tuckerdog1
01-31-2018, 06:48 AM
ARLO
R
are usually just trade the camper in the buy a new one. If the tires are worn out, There is probably other stuff getting ready to go to.o.
01-31-2018, 07:50 AM
is there an official guide or manual showing the proper jacking points and locations for jack stand?
2011 A-122
01-31-2018, 08:18 AM
Had to replace/buy a Tire in Calif.,told the Service writer/Manager that I had Ramps to raise the wheel when they decided where they were going to remove the tire! Next thing I see is a Worker pulling a Jack across the Lot to jack up Our Trailer! I stopped him before he jacked up on the "AXLE"! You have to take care of your OWN things! Youroo!!
01-31-2018, 08:30 AM
Unfortunately there's not. However there's several Youtube videos that show how to do it. Here one that has a good view of the jacking point starting at about the 1 minute mark.
Gotta go campin!
01-31-2018, 10:29 AM
In the old days,
you could change a tire on a rim by hammering a chisel into the seal,
and then switching the chisel to a crowbar.
Nowadays, a tire changing machine, or a tire shop is the way to go!
01-31-2018, 07:15 PM
I'm at the same point with my tires...I have 2 new load range d s in the garage.
I will jack one side...remove the wheel ...replace with the spare... then drop.
other side I will jack...remove the wheel...and leave the hydrolic in place with a support to the front of the wheel.
chock everything...so no movement is an issue....and off to your local mechanic you go.
my guy does it for about 25 bucks a wheel...balanced.
most garages have the ability to do 13 inchers...as new equipment had to be purchased in the last 10 years to enable them to do all sorts of rims.
dmo
2008 Nissan Frontier 4x4
2011 Rockwood A122
