11-08-2016, 08:11 AM
Blow out plug
I'm thinking about using an air compressor to blow out the water lines this year.. instead of using RV anti freeze. Can someone provide info on the procedure? Exactly what kind of "blow out plug" do I need? Where does it attach? How much pressure, etc? This is on an aframe camper.. not your normal travel trailer. I have a 2014 Rockwood a122s. Thanks for any comments.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
11-08-2016, 08:50 AM
blow out plug
The plug is available at Walmart et. al. Camco makes one. Screw it in to the city water connection, attach your compressor to it, and blow one faucet/outlet/toilet at a time. Thirty lbs. Don't forget the outside shower.
kdot
2019 Flagstaff E-Pro 19FBS
2017 Honda Pilot
11-08-2016, 08:58 AM
Camco makes a couple of types of blow out plugs with different ways to secure a air hose depending on what type of air hose fitting you will be using, check out their web site. Walmart usually has them or a local RV dealer. It screws into the water inlet port on the outside of your trailer where you attach your water hose at the campground. You only need about 20lbs of air pressure, when you have applied pressure in the line open up one tap at a time for a couple seconds to expel some water, close the tap to re-pressurize the line and open it again. Repeat until just air comes out of the tap. Do this to any fixtures in the trailer that provide water.
http://www.camco.net/product/blow-out-plugs-10273/
2017 Ford F250 Lariat Diesel 4x4
2012 Sabre 31RETS
11-08-2016, 09:15 AM
Always Learning
The instructions above are good. This article contains links to blowout plugs and more for winterizing.
http://learntorv.com/winterizing-you...-water-system/
11-08-2016, 09:33 AM
Also don't forget to open both low point drains. Blow out winterizing is ok in southern climates and is what I do if it's even needed. But I would not trust it for a long hard wintertime. For an overnight hard freeze (low 20's) I'll also set an electric heater in the camper on low.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
11-08-2016, 09:58 AM
I blow mine out in Northern Illinois. It goes to -25F here. Last year we had almost 3 weeks where it didn't go above -10F. No problems.
The change in ice density between 32F and -25F is small. Once the ice freezes at 32F, it's expansion rate goes down.
Chuck9997: Don't forget you still need AF in the drain traps and toilet.
2011 Traverse LT, 3.6L, FWD
11-08-2016, 10:05 AM
Bull, I live in a so called hard winter climate and have done this for 15 yrs with no issue. antifreeze in all drains and toilets and off you go...
Stefan
2014 - Sabre 36 QBOK
Nights camped 2014 - 38
Nights camped 2015 - 46
Nights camped 2016 - 43
Nights camped 2017 - 2
11-08-2016, 11:34 AM
What about the end of the plug that attaches to the air compressor? The plugs I have seen say quick connect. Will they fit on the standard air compressor fitting that I use to air up my tires?
11-08-2016, 11:43 AM
Pooneil. . Do you open the low point drains before blowing out the lines? During? Or after? Do you close the low point drains when u are finished?
11-08-2016, 12:16 PM
If you have something that looks like this:
It will fit on something like this:
Even better IMHO, would be these two things:
Either way will connect your compressor to your water inlet.
11-08-2016, 12:46 PM
X2 This is what I use with 25 to 30 psi and an OIL-LESS compressor
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
11-08-2016, 02:28 PM
found the first piece on amazon.. $7.. whats the second piece called?.. and what size? Found something similar but it's $33.
11-08-2016, 02:49 PM
Not sure exactly what it's called but it's the piece that goes on the end of the hose coming out of your compressor. Assuming you already have a compressor, you can get an entire starter kit from Harbor Freight for about $15.
Air Tool Accessory Kits
If you don't have one, you can usually catch them on sale for around $50. It's where I got mine and it's worked well for the past 5 years or so that I've had it.
11-08-2016, 02:54 PM
It is called a quick connect coupler. (AKA socket)
The first piece is a quick connect plug.
11-08-2016, 02:56 PM
I use this and a good quality bicycle pump. Use the pump to get 20 psi, open a tap, repeat. No need for a compressor.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
11-08-2016, 03:09 PM
That sounds immensely time-consuming. With the quick connectors, I can set the compressor to whatever PSI I want, turn it on and then go inside and open each tap. With 3 sinks, 2 toilets, and 2 showers (one in, one out) I'm still done in 10 minutes or less. It would take me half the day with a bicycle pump.
11-08-2016, 03:16 PM
I can see if you are by yourself that would be true. My wife helps so I pump and she opens taps. Last year we winterized the whole TT in under 30 minutes including blowing out lines and pumping in the pink stuff. Each person has their method...
Lee and Anne
11-08-2016, 03:18 PM
Ah... Mine was a 3-person job. I did all the work while my father and father-in-law stood around and BS'd.
11-08-2016, 03:27 PM
Lee and Anne
11-08-2016, 03:30 PM
My DW helps too... but mostly it is just to tell me what she thinks I'm doing wrong!
