Originally Posted by Alben
Considering that this is the A-frame forum, I doubt many A-frame people have a current draw that exceeds 60 Amps The stock trailer wiring to the battery is only 8 AWG.
This is also true of many Travel Trailers. #8 Awg wire from 55-60 amp converter to battery.
The issue arises when people install an inverter to run a microwave, coffee pot, or other appliances and install the inverter next to the battery on it's own wires (often #6 or larger). Current can be a lot higher than 60 amp although for a short time unless they've added more battery capacity.
The 60 amp limitation would only affect those who are running Inverters or other high draw accessories. The solution is simple, just add a larger shunt and adjust settings. Things that are worth noting if one is shopping for a lower cost monitor than those like the Victron. To make it apples to apples with those that use larger shunts for higher current, extra cost is necessary.
No stones being thrown at the unit in discussion.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
