Old 09-01-2015, 11:17 AM   #1
Abby's Avatar
Brake/Turn Indicator Light not Working
The left hand brake/turn indicator light on my A122 isn't working. The signals on the TV are working OK. Is this a fuse or wiring problem, or possibly a bulb?
Thanks in advance,
Tad
Abby is offline   Reply With Quote
Old 09-01-2015, 11:30 AM   #2
clr
Always start with the simple stuff first, check the bulb first. If it was working before that is the probable cause. Since the break and turn lights are in separate wires and fuses in most TVs I would suspect the bulb first.
clr is offline   Reply With Quote
Old 09-01-2015, 11:46 AM   #3
William
WEMig's Avatar
What tow vehicle do you have? Just went through this with my F 250. My truck has separate relays for trailer functions, which were not working. It didn't affect my trailer running lights or my trucks functions.
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 09-01-2015, 11:52 AM   #4
Bob P's Avatar
Trailer Light
Just had that problem with the right rear trailer light. Found it to be a poor connection at the 7 pin plug connection at the tow vehicle. Good luck.
2015 Flagstaff T12TST A Frame
2011 Toy. Sienna w/tow prep
Bob P is offline   Reply With Quote
Old 09-01-2015, 06:36 PM   #5
I also had this problem. It was one of the pins on 7 pin connector. Cleaned and tightened corresponding pin connector. Use of a volt meter at TV connector will allow you to locate pin for turn/stop lights. Put turn signal on and check for 12 volts on each pin. When the meter alternates from 12 to 0 volts you have found the appropriate pin. If you do not get on and off voltage then it is not the connector but a problem before the TV connector. Check bulb first, if OK then it is likely the bargman 7 pin connector.
mzak is offline   Reply With Quote
Old 09-04-2015, 09:56 AM   #6
Abby's Avatar
E150. That's what the problem turned out to be. It has a separate fuse box in the engine compartment which is for trailer functions. It was just a blown fuse.
Thanks for the advice everyone, you were a great help and I learned a lot.
cat, light, brakes
