Old 07-17-2016, 01:07 PM   #11
Originally Posted by chuck9997 View Post
If (when) the bungee fails.. what is the immediate result? Can the roof panels still be raised? Can you still set it up safely until the repair is made?
I guess I am asking what the function the bungee (or bungees) is.
The bunges function to keep the roof halves together when raising the roof. Both to keep the front from getting loose by catching the wind and to keep the bottom from running out from under the top section, allowing the top to fall.
The same could be done with rope, as the guy at the aliners site showed. But the bunges will keep tighter control on the upper section.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
roo, roof
