Old 10-04-2018, 08:53 PM   #21
2TR
Has any one used flextape for the window leaks?
2TR is offline   Reply With Quote
Old 10-04-2018, 09:00 PM   #22
Not sure what Flextape is, sounds like one of those As Seen On TV items, stay away. I used Eternabond tape four years ago, holding like the day I installed it and never had a leak.Better to go with a proven product in my book.
sundancer330 is offline   Reply With Quote
Old 10-04-2018, 10:01 PM   #23
Just as confused as you
Scrapper's Avatar
X2. FlexSeal FlexTape is not recommended. FlexSeal products do not last long and are not compatible with many sealants used by the RV industry.
Eternabond is the best thing to use on all seams. It is warranted for 10yrs when properly applied following the manufacturers directions.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 10-10-2018, 07:55 PM   #24
Leaking windows
I had a leaky back bubble window on my 2014 A122. I applied Eternabond but still had the leak. The problem turned out to be tiny cracks in the corner of the window itself, not the seal around it. I used a product referenced in other posts, Cap't Tolley's Creeping Crack Cure, and this seems to have done the job. Look at the corners of your window and check for the cracks. I used a magnifying glass to see mine. I found cracks on one of the front windows too and applied the stuff there too. I'm not unhappy with applying Eternabond as it sounds like it is just a matter of time before the seals leak.
grub is offline   Reply With Quote
Old 11-28-2019, 11:01 AM   #25
Hi we have a A- frame Rockwell I used eterna bond tape 1” works very well our back & front window was leaking a little after the first year. So far no leaks I bought mine on ebay.
Erichkathy is offline   Reply With Quote
Old 11-30-2019, 01:07 PM   #26
Just had the Eternabond delivered 1 hour ago from Amazon. Now I need to learn on YouTube and wait until the rain stops. Oh, need to buy the heavy roller.
After that, need to fix the broken valve on the toilet. Maybe when I fix the stuff, it will be better than new.
2014 Nissan Pathfinder AWD w/Tow pkg
2017 Flagstaff T21TBHW
traveling.geocacher is offline   Reply With Quote
Old 11-30-2019, 01:51 PM   #27
HONDAMAN174's Avatar
Or at the least the satisfaction of doing it yourself.
Just glad to get away
window
