Old 08-20-2018, 04:09 PM   #1
Bubble windows
Our 2 bubble windows leak on our A-frame trailer, What is the best way to repair them? Thanks
Paul V is offline   Reply With Quote
Old 08-20-2018, 09:06 PM   #2
Many people are using eternabond tape
mtmurphy56 is offline   Reply With Quote
Old 08-21-2018, 07:24 AM   #3
backpacker3's Avatar
X2
Eternabond is the best. Just had 7.5 inches of rain here yesterday and no leaks.
2019 Flagstaff 206STSE
2017 Chevy Colorado Z71 4x4 V6
backpacker3 is offline   Reply With Quote
Old 08-21-2018, 08:49 PM   #4
Eternabond tape has worked great, I had heard of so many with skylight leaks I taped mine the first week I owned it, three years and no leaks. Watch a Youtube video on how to install, make sure you buy the roller as this is what activates the bond. great stuff
sundancer330 is offline   Reply With Quote
Old 08-22-2018, 11:24 AM   #5
JArry's Avatar
X4 on Eternabond
2016 Flagstaff T12RBST A-Frame (same as Rockwood A122S) | 2006 Honda Ridgeline RTL
Nights camped in 2016: 37; 2017: 52; 2018: 47; 2019: 57
JArry is offline   Reply With Quote
Old 08-22-2018, 02:27 PM   #6
The website for Eternabond says you need to remove the silicone sealant. Has that been anyone’s experience?
Old 08-23-2018, 04:45 AM   #7
steve02bat's Avatar
You absolutely do not need to remove the previous sealant. The eternabond tape is nice and wide and completely covers it. I did mine a year ago and it's working great. Be sure to use the roller to activate it. It's a little expensive but it's designed to be heavy and it's what makes it work.
steve02bat is offline   Reply With Quote
Old 08-24-2018, 08:10 AM   #8
Thanks so much, Steve
Old 08-24-2018, 12:01 PM   #9
I doubt FR used silicone as a sealant since its the worst sealant to use on the exterior of an RV. I taped right over the existing sealant and have had no problems with the seal or any tape lifting, looks just as good as the day I installed it three years ago
Old 08-24-2018, 09:56 PM   #10
The stainless roller looks great, but a bit pricey. This one was recommended on Amazon with the Eternabond tape and is $13.50. Has anyone used a rubber roller and/or what do you guys think?
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
Russ (A122)
rboutell is offline   Reply With Quote
Old 08-25-2018, 07:37 AM   #11
That's the one we used. It did the job.
2018 A213HW
2018 Chevrolet Colorado with tow package
lcangler is offline   Reply With Quote
Old 08-25-2018, 10:39 AM   #12
I bought the Eternabond roller, after watching a few youtube videos I saw it was critical to use the heavy roller to get a good bond. The tape has whats similar to a layer of sealant on it, to activate and get a good bond you have to use pressure on the tape when rolling to get this sealant to ooze out along the edge. That wallpaper roller may work just fine but I didn't want to chance it and have to do the process again due to the tape not bonding as it should have
Old 08-25-2018, 11:53 AM   #13
Just as confused as you
Scrapper's Avatar
I bought the Eternabond roller. One side is squared the other side is rounded. makes it great for those odd shapes next to and over the old sealant.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 08-25-2018, 02:53 PM   #14
Me, I went the cheap way and bought a .99 cent plastic wallpaper roller at Walmart and it worked just fine. It has been a year and a half since I put the Eternabond on and it is holding up just fine. IMHO when you use an adhesive any any kind, a very clean surface is what counts the most.
On my last AFrame, I did it the same way and after five years, was still holding up great.
Old 08-27-2018, 06:43 AM   #15
I bought that exact roller for doing this same job, I would not recommend it. It does work but it doesn't roll smoothly when you put pressure on it.
p40whk is offline   Reply With Quote
Old 09-02-2018, 02:30 PM   #16
JArry's Avatar
I got this one, too, and it worked fine, but I really have nothing to compare it to.
Old 09-05-2018, 06:17 PM   #17
Not to hijack this thread more
How about the corners, overlap or 45 deg cuts?
Thanks.
Russ (A122)
Old 09-05-2018, 08:17 PM   #18
Thanks.
I overlapped mine and started with the bottom strip first then laid the sides on top of that then the top over the sides. This way the water will not catch on any seams. This stuff is so sticky it might be difficult getting a good miter joint.
Old 09-05-2018, 08:36 PM   #19
JArry's Avatar
About the same for me - could be prettier, but about all I care about is whether or not it leaks.
Old 09-07-2018, 01:12 PM   #20
I used sikaflex # 221 colk mine also leaked. Worked very well but messy
Erichkathy is offline   Reply With Quote
window
« Cover over A-Frame | - »
