Old 05-19-2015, 08:27 AM   #1
OutAndAbout's Avatar
Bungee Cords ???
I have an A122S that is only a couple years old. The first winter I stored it with the roof down. This past winter I stored it with the roof up. Its always under a rv-port (car-port) when home. From the day I bought it up to the last outing last fall the roof raised as it should, push up on the front roof and the rear roof follows along being pulled up by the bungee cords and moves into place without much effort. My first outing this spring didn’t go that way at all. During the outing I raised the roof 3 times and all 3 times the rear roof lagged behind to the point that I had to basically push up on both sections at the same time to get them into place. Not an easy task and a poor selling point for rockwood in a crowded campground. I have looked everything over and can find nothing wrong other than the bungee cords don’t seem to be doing there job. Any comments, opinions, and advise on bungee cord replacing would be appreciated. Thanks
Never try to teach a pig to sing, it's a waste of time and annoys the hell out of the pig.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
OutAndAbout is offline   Reply With Quote
Old 05-19-2015, 08:53 AM   #2
Raise the roof by pushing up on the back section. The sections will easily fit together then.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 05-19-2015, 08:58 AM   #3
Thanks Tom. I'll give that a try.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
Old 05-19-2015, 09:11 AM   #4
RedLdr1's Avatar
I'm not sure it is the bungee cords. The other thing to check is the torsion bars used to provide the lifting force. After sitting in the "up position" all winter I wonder if they have lost some of their "spring".
It is my understanding the bungee cords are there to help control the lifting force provided by the torsion bars and you, by keeping the panels lift rate close, not to provide the lift. They also help keep the panels close when lowering the roof and provide some wind protection.
Do the roof panels start to lift on their own when you begin to raise the roof? Since our T21QBHW has a roof power lift I can't compare it to your A122. I do know our front panel easily spring up a little when I unlatch the roof and lightly push up on the front panel. After that the lift kit raises the rear panel while pushing the front panel up.
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 05-19-2015, 09:29 AM   #5
Boss Ox & Drovergirl
oxcamper's Avatar
Perhaps the bungee cords are loosing their elastisticity over the years. Can they be replaced?
While I'm not familiar with your unit, I do use various types of these cords as tie downs for a multiple of purposes and they do loose some "oomph" (that's a technical term) over time. Good luck with a solution.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 05-19-2015, 01:36 PM   #6
Tom, I tried by pushing up on the rear panel only and it worked. But not as easy as before now.
RedLdr1, I checked the torsion bars, they are hard against the roof even in the up position. Also in the up position there is less torque on the bars which I would think would be better than in the down position where they are under more torque.
As you raise the roof by pushing up on the front portion the bungee cords ‘lift’ the rear portion while at the same time they stretch, then at the last foot or two they contract giving the rear portion an extra little oomph to get it into it’s final position. I would think that if they were only for ‘control’ Forest River would use something like nylon straps that wouldn’t ware out so quick.
When I unlatch the roof the front panel will raise an inch or so and the rear panel slightly less. About the same as before this problem started.
Until now I never had to push on the rear panel at all, the bungee cords would contract and pull it into position so that it would slip into the slot of the front panel. Now it hangs down about a foot and half below where it needs to be.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
Old 05-19-2015, 02:57 PM   #7
DanM-AZ's Avatar
I agree with Tom. You are supposed to raise the roof by pushing up the rear portion. You may start the raise by giving the front portion a boost with your hand, but past a certain point, the raising is all done by pushing up the rear roof section until it engages the slot at the top of the front slope.
You lower the roof by pushing up the front portion, which drops the rear out of engagement from the slot in the front portion, allowing both panels to drop down, the rear portion being controlled in its descent by the bungees.
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
DanM-AZ is offline   Reply With Quote
Old 05-19-2015, 04:04 PM   #8
Mine has gotten heavier over last two years. I suspect it is the lift springs giving up. Lifting from the rear is what is stated in the manual.
Tom
2012 Rockwood A122S
Old 05-19-2015, 06:18 PM   #9
Hay come on Tom, who reads manuals? What you and DanM-AZ make a lot of sense. I’ll have to get the manual out, I think I saw one somewhere. Actually I was doing it the way they showed me at the dealer when I picked it up, by raising the rear panel by lifting up the front panel. That worked real good until the cords got weak. Thanks everybody for your input and advise. I will consider this problem “SOLVED”.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
Old 05-19-2015, 09:45 PM   #10
Ya, the did that to me too. But I watched a setup video from somewhere on the inter-tube and it showed how to do it the other way.
Tom
2012 Rockwood A122S
