Old 09-13-2015, 06:25 AM   #1
chuck9997's Avatar
Camco Cover Straps
I bought one of these CAMCO covers (http://www.amazon.com/gp/product/B00...ilpage_o03_s00) for my A122S. I like the cover, ok,.. and it will serve a purpose (still wish I had a garage or carport). Anyway... does anyone know the secret to using the bendable straps. There's seems to be no place, on the a122s, to hook the strap once you bend it into shape. The instructions show hooking it to the side of the camper under the frame. But that just doesn't seem to work with my camper.
I ended up using bungee cords. Going to go get some longer ones today if I can't figure out those bendable straps.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 09-13-2015, 02:21 PM   #2
I really like the cover but I received no instructions with mine. I'm going with the bungee cords too and attaching them to the frame rails. The cover has been through one tough Ontario winter so fall and through it wonderfully.
Rockwood A-122S
hhunter44 is offline   Reply With Quote
Old 09-13-2015, 09:53 PM   #3
From Amazon review:
Ok... after sitting stumped in the driveway for 10 minutes trying to figure out what the heck to do with the straps hanging from the cover and the bungie pieces in our hands... I stomped into the house and sat down to see who else complained that this makes no sense! Then I came across a VERY HELPFUL reviewer's post who explained what to do, lol. You take one of the straps hanging from the cover and tie it to the loop end of the bungie strap. Then you take the other end of the bungie strap that has the metal strip with fabric over it, and bend it into a u-shape and hook it right onto your campers frame. Repeat all the way around.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 09-13-2015, 10:08 PM   #4
chuck9997's Avatar
I received instructions with mine.. so I know about bending, etc. But there is no place on my a122s to hook them.
Old 09-13-2015, 10:15 PM   #5
Bummer, seems like there would be a place under edge of frame. You make me glad I have the carport
Old 09-14-2015, 09:04 AM   #6
chuck9997's Avatar
I'm going to double check. . Get down on the ground and get a better look. I'll let ya know.
Old 01-29-2016, 09:14 PM   #7
ccamper's Avatar
I know this reply is a bit late, but I thought I would share what I did with my Camco cover. I used ball bungees attached to the four stabilizer jacks for the corner straps. 2 center door side straps hooked to retracted door step frame. on the othet side, my A192hw has a frame member reinforcement with 3 holes in it. needed to use ball bungees for straps to reach. It covers entire camper box, spare tire, and propane tanks. I bought the 14'-16' cover and it's definitely long. The box Measures 15', go figure. I put a 3 gallon plastic bucket over the eletric tongue jack. Hooked the chains to the bucket handle. Tucked wiring up into the bucket, snd covered the whole front tongue with a tarp and ball bungees.
ccamper is offline   Reply With Quote
Old 01-29-2016, 09:48 PM   #8
ccamper's Avatar
Pics of my Camco cover
ID:	98585   Click image for larger version
ID:	98586   Click image for larger version
ID:	98587   Click image for larger version
Old 01-30-2016, 06:19 PM   #9
ccamper's Avatar
Some close ups of the straps
ID:	98643   Click image for larger version
ID:	98644   Click image for larger version
ID:	98645   Click image for larger version
Old 01-30-2016, 07:07 PM   #10
chuck9997's Avatar
Good job.. I made mine work.. used bungees. This is the first winter. I'll let you know, in a month or two, how it protected the camper. I also put a bucket over the power jack.. then a separate tarp over the jack, propane tanks and battery. Bungeed the tarp secure.
cover
