Old 05-07-2016, 07:37 AM   #1
Camper Wiring Harness Bad?????
Not sure where this should go so feel free to move it if it's in the wrong place.
2013 A128S Aframe......2012 Dodge Durango.
Last week started Durango and error light came on the dash...."faulty right rear turn signal"....in other words right turn signal isn't working. decided to replace the bulb the next day but got a call at 3:00 am that my brother had died so we left town....got pulled over by trooper for no right brake light. He was very nice and only gave me a warning ticket.
Turned out that it wasn't a bulb but the camper wiring harness....just unplugged it until I could get back home.
Any suggestions as to what to look for with the wiring harness? I'm not much with electrical but my neighbor is but he's gone for another week.
David
Tow Vehicle: 2012 Durango 3.6 Pentastar Engine
Total nights camping 2014-(10)
Total Nights Camping 2015-(9)
Total Nights Camping 2016-(5)
Total Nights Camping 2017-(4)
Total Nights Camping 2018-(7)
mlsa3 is offline   Reply With Quote
Old 05-07-2016, 08:05 AM   #2
Flybob's Avatar
Please provide a little more information.
Does Durango have OEM trailer package ( wiring )?
Was a trailer adapter module added to the wiring in the TV?
Were you towing the trailer when you got pulled over?
If you have an aftermarket adapter module in the TV connected to the TV lights then the trailer, it is possible that it failed ( could be many reasons).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-07-2016, 05:14 PM   #3
A first order guess would be short in the camper wiring. Look in the most likely places, those where connections are made and the wire moves. Get an electrical multi meter and start looking for continuity between every lead on the plug and the ground. And between each of the non-ground wires. Unplugged then plugged in if needed. The most likely place to find a fault is in plug itself, but it could be anywhere. The second place I would look is in and around the right tail light.
If the plug checks out OK (no continuity) when unplugged but the fault appears when plugged in, also inspect the jack on the TV for faulty wiring or a stray piece of metal before digging too much.
The fault could be anywhere, but elminite the likely and easily checked places first Then dig in if necessary or punt by taking it to a trailer shop.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 05-07-2016, 06:52 PM   #4
Did the op have a previous trailer?....things can get funky when trying to correct a previous issue . ..then it shows up on your newer trailer....trust me...this has happened before
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 05-08-2016, 01:37 PM   #5
Stormrider151's Avatar
I'm sorry about your brother. Prayers for you and your family.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-08-2016, 02:04 PM   #6
Check ground connections. Many times loose or corroded.
Harkerr is offline   Reply With Quote
Old 05-08-2016, 02:31 PM   #7
I,d start with the right camper
Light and light assembly.
Be careful taking off plastic cover.
Sorry about your brother.
Harness connection and near wiring next.
Good luck.
mickrock is online now   Reply With Quote
Old 05-08-2016, 04:56 PM   #8
Thanks for all your replies. Been busy for the past couple of days. My neighbor is back home now so I'll get him to help me trace the problem. He has all of the electrical tools we'll need to find the problem.
I'll let you all know what I find once we're done fixing it.
David
Old 05-12-2016, 09:34 AM   #9
Not sure what was going on with my wiring but when my neighbor came over to look at it he put some type of grease on the plugs and plugged it back in....works great...been using it for a couple of days now and no sign of a problem thank goodness.
Now to plan a camping trip next week.
David
camper, wiring
