Old 01-07-2018, 12:48 PM   #1
Capacitive touch thermostat
Can not seem to regulate thermostat to keep inside temperature at steady temperature. There is almost a 8 degree difference to get it to come on. Set on 74 , gets down to 66 than comes on. Do I need to adjust something? Have A214HW.
Banjo64 is offline   Reply With Quote
Old 01-07-2018, 08:23 PM   #2
Furnace or Cool Cat?
carlsbad is online now   Reply With Quote
Old 01-07-2018, 10:53 PM   #3
Furnace
Old 01-08-2018, 08:26 AM   #4
Head Rambler
What is the make and model number of the thermostat?
Where is the thermostat located in the RV?
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 01-08-2018, 02:05 PM   #5
Here is a link to the Dometic thermostat manual, may need to adjust some settings.
http://www.gulfstreamcoach.com/media...tat-Manual.pdf
sundancer330 is offline   Reply With Quote
Old 01-10-2018, 12:27 AM   #6
I just did a first camping trip in my 194HW in cold weather... and yeah, there's a huge difference in temperature when the furnace turns off (and it's warm inside) and when it finally turns back on (when it gets cold). I'd say 8 degrees sounds about right.
I'm wondering if the Dometic thermostat has the temperature sensor on the BACK... which would be inside the cabinet with the microwave in it. I could see that being a factor in the wide temperature swings - the temperature would take longer to both increase and to decrease in a smaller enclosed space like that cabinet. I may have to pull the thermostat off and see if I can see where the sensor bit is.
FrayAdjacent is offline   Reply With Quote
Old 01-10-2018, 12:17 PM   #7
Head Rambler
I don't know where the thermistor is on the capacitive models is, but on the LCD units it's right at the bottom near the back of the case.
Gotta go campin!
Old 01-10-2018, 03:10 PM   #8
And I'm guessing (I guess I could go out to the garage and look at mine) that it's really going to be measuring temperature inside the cabinet behind the microwave.
Old 01-11-2018, 12:04 PM   #9
in 2011 we got the non digital thermo..
I'm thinking in 2012 the digital units were installed.
you have to think about the space your heating...not big...at all.
I would think that the furnace has a lag time to turn back on if it shut off...to protect circuits, heat exchanger and whatever.
if you notice...the furnace does not shut down after de-firing...the fan stays on to remove the heat from the exchanger.
just my thoughts
dmo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 01-11-2018, 01:38 PM   #10
At home if I set the thermostat downstairs to 64 it is 68 in the bedrooms. I suppose if I wanted it 64 upstairs I could just lower the darn thing to 61 and see how it works out.
thermostat
