Old 07-01-2016, 10:34 PM   #11
Originally Posted by NancyCas View Post
Ya know I'd like to know the answer to these questions and after sitting and studying the matter, or I should say laying on the bed and looking up at them for at least a half hour I decided that who ever placed them there must have had a long night. I hooked the shelving unit up to it and can't find any way to use both the shelving unit and the pull down rack. One gets in the way of the other. My conclusion is the hooks should have been put in over the microwave not over the sink.
Just had this same conversation with my husband. What an awful placement. Kinda like placing the Emergency Exit - you know, in case of FIRE - directly over the stove - you know - the thing that would be on fire! Duh
Originally Posted by kwf1958 View Post
I'm beginning to suspect there's no rhyme or reason for the location. According to the tech rep from the factory with whom I spoke those d-ring loops aren't anchored into anything more substantial than thin sheet metal. I wouldn't hang more than 10lbs in that rack. I asked if the roof panels had any structural framing to which he said only on the perimeter. I've come up with an elegant solution I do believe. I'll be posting pictures in a day or so. My solution involves attaching d-ring anchors to the roof above the sink/refrigerator counter in my A212HW just below the levers that lock that side to the roof panels. Using carabiners I then clip a reinforced 6'4" wire closet shelf from Home Depot to the d-rings. I then hang 4 wire baskets and a paper towel dispenser from the shelf. The storage space is awesome.
Would love to see a picture of this set up!
Mama is offline   Reply With Quote
Old 07-02-2016, 12:12 PM   #12
Am anxious to see you new storage area.
NancyCas is offline   Reply With Quote
Old 07-04-2016, 09:26 PM   #13
Can't wait to see this set up!
2016 Forest River Flagstaff 12RBST
Old 07-06-2016, 09:17 PM   #14
Ok campers, I got the shelf in and the wife and I love it. Here's the finished product loaded up.
Name:   ImageUploadedByForest River Forums1467856422.151269.jpg
To start with I located my d-ring hooks far enough down from the roof peak so as not to be a problem when the roof is collapsed flat. As you can see they are slightly below the locking levers for the side. Additionally, I placed the a bit over 4" from the wall and the second one an additional12" from the first. My shelf is 12" deep.
Name:   ImageUploadedByForest River Forums1467856834.582743.jpg
Name:   ImageUploadedByForest River Forums1467856846.306240.jpg
Name:   ImageUploadedByForest River Forums1467856862.862844.jpg
To attach the d-rings I cut some 1/8" x 2" steel flat stock into 3" plates, drilled, sanded, primed, and painted to match on the outside of the roof. I used 1/4" x 2" stainless steel screws and nuts and a generous coating of silicone caulk between the plates and roof.
Name:   ImageUploadedByForest River Forums1467857181.617735.jpg
Name:   ImageUploadedByForest River Forums1467857203.314237.jpg
Name:   ImageUploadedByForest River Forums1467857226.820981.jpg
Looking back on it I wish I'd mounted the d-ring 90 from current. Would be easier to attach the type of clips I chose. I attached, with zip ties, a round ridged curtain rod, painted white, to the back of the closet shelving to keep the shelf from sagging. I used sturdy clips to attach the shelf first to the rear d-ring then to the front.
Name:   ImageUploadedByForest River Forums1467857591.042050.jpg
Name:   ImageUploadedByForest River Forums1467857607.408534.jpg
Name:   ImageUploadedByForest River Forums1467857626.954392.jpg
Name:   ImageUploadedByForest River Forums1467857671.195047.jpg
Once the shelf is hung I suspend wire hanging baskets from the shelf. You might also notice I now have a place to mount my paper towel holder.
kwf1958 is offline   Reply With Quote
Old 07-06-2016, 09:20 PM   #15
Name:   ImageUploadedByForest River Forums1467857873.945301.jpg
Name:   ImageUploadedByForest River Forums1467857887.828185.jpg
Name:   ImageUploadedByForest River Forums1467857901.629936.jpg
The width of the shelf is about an inch or two under the width of the camper so it stores nicely on the back queen sized bed.
Name:   ImageUploadedByForest River Forums1467858027.846764.jpg
If you've any question feel free to ask.
Ken
Old 07-07-2016, 10:23 AM   #16
World Traveler Member
abdiver's Avatar
Do not put any real weight on the hooks since they are in Very Thin sheet metal. Just for example the curtains have a Velcro pad screwed into the siding and I find them pulled out once and a while and I have to push them Back in. I like the idea of using the Hanging clothes bar to support a little more weight.
2014 A194HW
2004 Toyota 4runner V8 4WD
abdiver is offline   Reply With Quote
Old 07-18-2016, 12:42 PM   #17
2TR
STORAGE
How are the shelves holding up. Any leak issues.
2TR is offline   Reply With Quote
Old 07-18-2016, 11:46 PM   #18
MY hooks are securely anchored to plate steel on exterior of camper. I've had it loaded with about 50 lbs.
Old 07-18-2016, 11:47 PM   #19
Holding up very well. No leaks and we've had lots of rain.
