Old 07-08-2016, 09:11 AM   #1
Closet rod for hanging stuff
A framers, do you use an adjustable closet rod between the peaks of the walls? What size did you get?
I'm thinking it would be very handy for drying towels, etc. when the weather isn't cooperating outside, but then again I don't want to damage the walls, either.
Jodilc is offline   Reply With Quote
Old 07-09-2016, 08:48 AM   #2
Yes I do...it is a adjustable rod that I put into two round furniture leg cushions mounted on the top of the walls that keep it in place. I think I bought it at WalMart and it is over 80" long.
I use it to hang towels and a wire basket in the unused space at the top of the A frame. I think it also serves to give a bit of opposing support to the two walls on windy days.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 07-09-2016, 10:39 AM   #3
chuck9997's Avatar
What exactly did you use to support the rod? And how did you mount the two supports to the wall?
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 07-09-2016, 11:13 AM   #4
I use this. It is a cargo bar from harbor freight. With coupon around $10
2-in-1 Support/Cargo Bar
ID:	113547   Click image for larger version
2012 Rockwood a124
mzak is offline   Reply With Quote
Old 07-09-2016, 05:20 PM   #5
I use the 2-in-1 Support/Cargo bars too. I put two of them up, one on each side of the "A" wall, so I can place a closet shelf on them for storage.
brewjaz is offline   Reply With Quote
Old 07-09-2016, 05:36 PM   #6
Not my photo, but one similar:
Old 07-09-2016, 06:45 PM   #7
chuck9997's Avatar
Does the cargo bar, from harbor freight, stay up with just pressure on the sidewalls? If so.. is it ok having that constant pushing outward on the walls. Maybe it helps to seal the walls better. IDK.
Old 07-09-2016, 06:59 PM   #8
I used to put the cargo pole on the metal strip at the edges of the "A" wall. I later added these Everbilt 1-5/8 in. Wood Pole Sockets (2-Pack)-15435 - The Home Depot
I'm hoping it will make it a bit more secure. I attached them with double sided tape.
So far (after a yr. of camping)---no damage to walls. Again---I try and position the poles on the metal edge.
Old 07-10-2016, 01:17 AM   #9
I also use the metal edge to tension against. Haven't had any problems to date. With that said I do not hang excessively heavy items on it and do not put excessive tension on the a walls when putting bar up. It also firms up the gaskets between a wall and roof panel. some aframe owners from other manufacturers also use this to keep high winds from collapsing a-walls but don't think that's a big issue. At least I don't remember anyone having their a walls being collapsed by high winds on this forum.
2012 Rockwood a124
