Old 12-05-2014, 06:30 PM   #1
CO alarm came on on our last trip
We have a Rockwood A192HW Hardside. We purchased it last May, made a 5700 mile trip last summer and all systems performed magnificently. However, went on a short trip several weeks ago and one day the CO alarm came on. Thank God it was in the middle of the day and not at night. Anyway, did what you are supposed to do, open doors and windows, turned off gas, etc. The problem was with the water heater. It had failed to ignite and after three attempts, it locks out indicated by the Red light. Later I tried it again, and it did ignite and ran for an hour or so before the alarm came on again. This time I turned it off and certainly was not going to run it at night after we went to bed. I tried it again the next day, and it seemed to be okay as the alarm did not come on again.
However, until I understand better what may have been going on, I would be real skittish about having it on at night when we are sleeping. Has anyone else had this problem and how did you resolve it.
Macjack
macjack39 is offline   Reply With Quote
Old 12-06-2014, 07:44 AM   #2
Mine has done the same thing. The last couple of trips it didn't happen.
We don't use the propane much so it's not a major problem for us although I want everything working correctly in case we do use it.
I checked for propane leaks and found nothing. Like I said I tried it on each trip just to see if it would go off again and nothing so hopefully whatever it was has cleared up.
Tow Vehicle: 2012 Durango 3.6 Pentastar Engine
Total nights camping 2014-(10)
Total Nights Camping 2015-(9)
Total Nights Camping 2016-(5)
Total Nights Camping 2017-(4)
Total Nights Camping 2018-(7)
mlsa3 is offline   Reply With Quote
Old 12-06-2014, 07:55 AM   #3
RPAspey's Avatar
Something that could be your problem is a blocked jet or combustion chamber. It seems that mud wasps and spiders like to build nests or webs in those areas. Oh, same thing could happen in the fridge and water heater. I'd check it out before taking to dealer.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is online now   Reply With Quote
Old 12-06-2014, 08:39 AM   #4
Are we talking just he CO2 alarm or the co2/propane combo unit?... The plain Jane Co2 units should not be set off by leaking propane....(CO2 is a product of combustion ).... Try replacing the detector..
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 12-06-2014, 08:55 AM   #5
beechjet16mf's Avatar
Our propane/ CO alarm has been going off all by itself. Nothing was on in the trailer. No propane, no burners, nothing, and it would only silence for 2 minutes. I had to dismantle it to stop it. I am going to buy a good one, not something made overseas.
2009 Suburban
Flagstaff 27RLWS
Phoxie Lou, the cat that runs the show
97 Nights and counting 2014
beechjet16mf is offline   Reply With Quote
Old 12-06-2014, 09:01 AM   #6
We had the same problem. It turned out to be altitude related. It happens the more you go over 4500 feet. Dealer can adjust the water heater so it won't happen at high altitude.
RichardEB is offline   Reply With Quote
Old 12-06-2014, 09:24 AM   #7
dcheatwood's Avatar
Mine does it in the driveway occasionally. I first tried resetting it several times. Finally went inside the house and ignored it. Went back out an hour or so later and it had reset. Both lp tanks were empty. I refilled and no more alarm yet. Thinking it may be connected to lp appliances trying to start when tanks are empty. ??? Good luck.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 12-06-2014, 10:04 AM   #8
BigTJohn's Avatar
Many times it is the connections on the back of the unit. Remove the unit, look at the connections with a magnifying glass and check for any loose wires. Remove the connections and clean the connection points. Re-install the wires and make good, solid contact. Removing power from the unit will also re-set it.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 12-06-2014, 02:19 PM   #9
TGR
TGR's Avatar
As BigTJohn shared, CO detectors are sensitive to voltage issues. Anyone who has let their batteries run down too far while dry camping will get a reminder from their CO detector that the trailer's battery's voltage is too low. Any poor electrical connections to the alarm may also cause the CO detector to alarm.
My only caution is that you should not jump to the conclusion that it's an alarm problem too soon as CO is colorless, odorless and dangerous. Until you are sure poor combustion isn't actually occurring, be cautious.
TGR is offline   Reply With Quote
Old 12-07-2014, 08:39 AM   #10
RPAspey's Avatar
The OP's problem is with the furnace. The alarm was an indication of a malfunction. If the furnace tried 3x to light,then lockout, gotta be a propane or ignition problem. Hopefully the OP will get us an update.
