Old 10-22-2011, 06:07 PM   #11
Mostly Harmless
thehamguy1's Avatar
Yeah, I guess it's silly to do all that rearranging. We'd like to go up the Alcan highway to Alaska next summer, so underbody clearance will be important. I don't actually know how much tongue weight the trailer has now, nor am I quite sure what our half-ton pickup will handle in that regard. Maybe the better route is to beef up the rear shocks and/or springs.
I do want to move the gas cylinder mount farther back. If I make a dual battery holder like yours, D-mo, maybe I can squnch it a bit farther back than it currently is and then shift the cylinder bracket.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 08-16-2012, 02:31 PM   #12
handbuilder's Avatar
I like this coat rack idea! Are you still using it as shown or has it morphed into something else or a different design?
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 08-16-2012, 03:06 PM   #13
Mostly Harmless
thehamguy1's Avatar
Still using it, in fact it's been quite handy here in the northland where the day goes from cold to hot and back again, and you need at least three levels of coat/sweater/shirt changes for each person. That'd all be laying on the bed without the coat rack.
2011 Rockwood A128
60W solar system
Old 08-16-2012, 03:31 PM   #14
We had our maiden voyage last weekend and the camping space we were assigned was right out in the Hot sunshine. It was great to turn on the A/C but noticed how hot the window areas became (and remained) and have been thinking of a way to install/sew an installing factor/material to the window coverings. Has anyone come with an idea?
You all have such great ideas. We did purchased the shelving unit that was suggested for over the stove.
JoArt is offline   Reply With Quote
Old 08-16-2012, 08:15 PM   #15
ThunderRoad's Avatar
Dammit, another hamguy mod I have to add to my list! :P
How did you attach it a the top? hooks over the wall or something on the rubber pads? couldn't tell very well from the pics.
2012 Lincoln MKX
2013 Rockwood A122BH A-Frame
ThunderRoad is offline   Reply With Quote
Old 08-16-2012, 09:53 PM   #16
Mostly Harmless
thehamguy1's Avatar
It hooks over the wall, and the rubber pads there keep the hooks from sliding down. The hooks are made from a coat hanger. I bent a loop in one end of each hook so I could screw it to the back of the board. The rest of the hook was bent as needed to hold it up there.
2011 Rockwood A128
60W solar system
Old 08-19-2012, 11:21 AM   #17
Yukon Don's Avatar
That's a good, simple idea for a coat rack, I'll likely make one of those up.
For what it's worth on the spare tire location, I've always found spares located under anything tend to rust, rot and seize there until you need them. And you always seem to need them when you're up to your axles in snow or mud...
Have you thought of a roof rack of some sort for your Silverado and putting the spare up there ?
Some racks do tend to hum at highway speeds (downside).
Adds that just-back-from-Kenya-on-assignment-with-National-Geographic look, if you put a spare tire or two up there (upside).
May well see you on the Alcan next year.
Yukon Don is offline   Reply With Quote
Old 08-19-2012, 01:35 PM   #18
Mostly Harmless
thehamguy1's Avatar
Cool roof rack idea, I'll have to cogitate upon that. I built a canoe rack, I can probably whip up something for the spare spare. As of now it's part of the swirl of flotsam in the pickup bed. I try not to look in there too often; just keep the tonneau closed and pretend everything's OK.
2011 Rockwood A128
60W solar system
a-frame
