Old 08-18-2013, 12:55 PM   #1
Movin up's Avatar
Confused about the water pump!
We are camping this weekend for the first time with hookups in our new a122s. We just completed a very successful 3 week trip, other than a frustrating leaking water filter. We had it "fixed", but it is stilll leaking.
Anyway, when we had in to the dealer, we asked about procedures for hook-ups vs dry camping. The guy told us to turn on the pump. I started reading the forums because our pump hums and fills the water filter slowly, but does not make the real pumping noize like it used to. From what I am reading on line, it looks like we messed up. Did we break our pump by running it while hooked up to water?
The pump is off now. I assume the water still has some way to get into the water heater. We have turned that off now, to be safe.
Cath (and Nick)2013 Hyundai Santa Fe 2.0 turbo
2014 a122s
Movin up is offline   Reply With Quote
Old 08-18-2013, 12:59 PM   #2
GSW
Sounds like not enough water in fresh water storage tank.
GSW is offline   Reply With Quote
Old 08-18-2013, 01:00 PM   #3
Triguy's Avatar
I am not sure what pump you have but I do not run my pump when on city water.
Are you saying that the pump, when running now with a filled fresh water tank, is not working (i.e. pressurizing) the lines?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-18-2013, 01:14 PM   #4
Movin up's Avatar
We do not have any water in the fresh water tank. I suppose you bypass the tank by using the city water, because we still have water coming out of the faucet. I guess that's why the pump s not pumping, there is no water to be pumped! I hope we have not damaged the pump by running it dry.
2014 a122s
Old 08-18-2013, 01:27 PM   #5
Triguy's Avatar
Possibly its damaged or maybe not. I'd test by filling up the FW tank, disconnecting from city water, and then turning on the pump. It will pressurize the lines and then shut off if everything is normal.
Scott
2012 Shamrock 233S
Old 08-18-2013, 02:59 PM   #6
bikendan's Avatar
didn't your dealer tell you that the water pump is only for the FW tank and not for city water?
if not, i'd give them a piece of my mind!
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-18-2013, 03:19 PM   #7
Movin up's Avatar
No, they did not. In fact they told us to turn on the pump when I asked specifically what we needed to, since we have only dry camped before. They responded quickly to our request to fix the water filter, but only re-installed the original, said the o ring was probably twisted, and tested very briefly. We were happy with the quick service, but would have preferred a new water filter. Now it is leaking again. Not feeling to wRm and fuzzy about em right now!
2014 a122s
Old 08-18-2013, 03:26 PM   #8
The pump in the a-frames isn't damaged by running dry so I expect you'll be fine.
2011 A-122
rawlus is offline   Reply With Quote
Old 08-18-2013, 03:52 PM   #9
I agree. The pump should not be damaged by running dry. It however has a finite life in running hours and running dry will count toward those hours.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 08-18-2013, 04:48 PM   #10
Movin up's Avatar
Thanks everyone for the input! This forum is fantastic.
We put a little water in the fw tank, and checked the pump, and all is fine. I don't like that we have used the pump unnecessarily, but it was less than 2 days. Now we know for next time we camp with hookups.
Again, so great to get responses so quickly!
2014 a122s
