Old 05-05-2013, 09:40 PM   #91
Originally Posted by WEMig View Post
This is the stove that I have. Best Butane stove for the money.
You can with the correct LP fittings.
Search results for: 'stove'
Thank you. That is the one I found when I searched Harbor Freight. Can you steer me in the right direction for the correct LP fittings between this stove and the connector already on the RVQ line? I know nothing about this.
We have a table that we had put on the RVQ rack on our PU that we intend to bring forward to our new rig. Looks like RVQ rack has changed and we may need to modify our table a bit, but won't know until our unit arrives.
Carla
2014 A122BH
18 Trips
47 Nights
20 Sites
6655 Miles
Carla is offline   Reply With Quote
Old 05-05-2013, 09:48 PM   #92
William
WEMig's Avatar
My camper is at the dealer for some minor repairs right now with the stove and hoses. I'd suggest you take the stove to your local hardware store that carries LP/butane supplies and fittings and I'm sure they can build you a hose just for that stove and the quick disconnect.
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 05-06-2013, 09:54 AM   #93
More specifically now, hubby thinks we should be able to hook our existing Coleman propane stove (small green canister connector) to the RVQ gas line. Does anyone know if there is an adapter that we can do this? Thanks for your help.
52 hours until pick up of A122BH (but who's counting...)
Carla
2014 A122BH
18 Trips
47 Nights
20 Sites
6655 Miles
Old 05-06-2013, 11:07 AM   #94
Don't Coleman stoves need high regulated pressure to operate at full output? The trailer LP system only supplies low regulated pressure.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 05-06-2013, 11:42 AM   #95
DGrissom's Avatar
Carla,
Have a great time with your A Frame. We have most thoroughly enjoyed ours!
It may be possible if you have the correct type of stove. One that will work with both low or high pressure.
Its my understanding that the regulated pressure from our larger tanks is provides too low a pressure to be useful on most propane campstoves.
As far as I can tell, my stove will not work (Coleman 2 burner) without extensive mods. (My stove): Amazon.com: Coleman Two-Burner Propane Stove: Sports & Outdoors
Note: I haven't validated this since I don't carry the stove on our trips as much as I used to. In the future, if I do, I will probably opt for the Harbor Freight refill adapter or continue to buy a tank or two every so often.
Most of our outdoor cooking is done with charcoal for grilling and Dutch oven cooking. We do use the RVQ (Side Grill) a lot (We even reheated some left over pizza in it last weekend.).
A comment about the RVQ fittings. They're not real easy to find. Our local LP gas company said that they could get them but it may take a while?? I think that I found them at Camping World. They were $$$!
If you successfully make the mods to the stove, post the how-to here! Again, have fun with your new camper!
David and Jo Ann G. (& Kenzie the Sheltie)
Prattville, Alabama
2018 Flagstaff E-Pro 19FD "Phoebe" 18 Nights!
2012 Rockwood A128S Nights Camped 2012 - 2017 = 226
Nights Camped 2018 = 6 as of today)
DGrissom is offline   Reply With Quote
