Old 09-23-2015, 11:04 AM   #21
After further inspection, my 2012 Flagstaff T12RB does have a drain, best viewed from curbside as the frame blocks the view on the street side. However, given the amount of drainage I get in Florida and siphoned out from the tubing, IT IS NOT DRAINING. I will again have to rely on my son to get under there and find out why when he changes the anode rod this coming weekend.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 09-24-2015, 01:15 PM   #22
Thanks, mzak for your detailed look at this.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 09-24-2015, 07:49 PM   #23
x2 mzak
Old 09-26-2015, 10:08 AM   #24
Jacink's Avatar
OK here it is I have a T21QBHW 2015
And I noticed the cool cat wasn't dripping from the two drip hoses on the side of the cool cat and we live here in Florida so there's a lot of humidity, to solve this problem By drilled up from the bottom of the camper into the bottom of the drip pan and attached to 1/4 inch hoses up from the bottom and that solve the problem.
Jacink is offline   Reply With Quote
Old 09-26-2015, 01:50 PM   #25
Jacink's Avatar
OK I too live in Florida and this is what I did for the dripping problem for the cool cat
I drilled up through the bottom of the camper with a 1/4" drill on both sides and with a hose adapter and a 1/4" clear tube. That seems to have solved the problem, and don't forget that you want your camper to be level to minimizing binding on the roof.
ID:	89945   Click image for larger version
Old 09-26-2015, 09:11 PM   #26
Darn shame to have to put holes in your floor to fix this OEM problem. Makes me think someone did not cut out the piece in the drain pan to match the floor drain. Tomorrow my son is fixing all my little stuff and will look at this as well once he get the anode rod out, anchors the new water pump and puts LED's in the ceiling for me. List just keeps growing.
cat, pump
