07-20-2016, 12:14 PM
Cooling the fridge
Next month I am making a 4 hour trip.. I will not be adding any food to the fridge before leaving. I will be buying a few things when I get there. I do not want to run the fridge on propane on the way to the CG.. Do you think it would cool down quicker, upon arrival.. if I put some frozen water jugs in the "turned off" fridge for the 4 hour trip? Or would they just melt in that length of time?
Anybody tried anything like this? Would the closed, turned off fridge, work like a cooler? or an oven?
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
07-20-2016, 12:20 PM
If you can, cool it down before you leave home. Turn off propane and don't open fridge until you get to site.
Or, just run the propane, I use to(now have residential fridge) and many others do also...
07-20-2016, 12:23 PM
Thanks.. thats what I usually do now.. for shorter trips.. didn't know how if the "cool" would last 4 hours.
07-20-2016, 12:47 PM
We cool our fridge down the day before on AC power. We then add the cold food and a half gallon milk jug of frozen water. We have the 3 way fridge. When traveling we switch to DC, powered by the tow vehicle ! Works great .
07-20-2016, 01:45 PM
Should be a good experiment then. cool at home and add the frozen ice jugs and let us know how it held up...or just cool it down at home and see how it holds up without jugs since you are not putting food in until you get there. That way you will know for future reference
07-20-2016, 05:01 PM
Basically what I do before travel. Cool 24 hours before I start travel. Have at lowest setting usually reaches 27 degrees. Have a cool of containers of frozen water in the bottom. And have my added fans going after six hours max I travel usually at about 37 degrees. When On multi day trips will stop and add ice to the containers. Will be switching out the 3 way this winter. Replacing with a compressor 2 way system
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Total (2104-2017) 319 2018 (59)
07-30-2016, 04:15 PM
We just returned from a 15-day trip. Plugged into house current 24-hours before we started our trip and turned the refrigerator on. Pre-chilled all the food prior to putting it in the refrigerator. Ran the frig off the battery while traveling. Travels days were 6-8 hours long. No problems. Food remained cold throughout our trip.
FLGrandCampers - Bill & Chris
Seminole, FL
2016 Flagstaff T21DMHW
2010 Ford F150 4 X 4
2016 nights camped 31
07-30-2016, 04:35 PM
Just curious why you don't want to cool the fridge at home and then run on propane while travelling. Is it the because of the chance of fire? I travel with the propane on whenever we travel.
Mark and Joanne
07-30-2016, 06:53 PM
Sometimes these three way fridges on small campers blow out when driving.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
07-30-2016, 08:22 PM
When I had my popup camper with a "ice box" not a refridge, I used dry ice to cool it. It does not melt and drip water like regular ice and will last for several days. WARNING: DO NOT TOUCH DRY ICE WITH YOUR BARE HANDS! WEAR GLOVES OR KEEP IT WRAPPED IN NEWSPAPER.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
07-31-2016, 06:06 AM
With the 3 way fridge you are not forced to . The DC side works .
07-31-2016, 08:01 AM
Does this run down the tow vehicle battery? Or does it pull DC from the camper battery? In that case.. would it be a drain on the camper battery?
I have a 2014 Rockwood a122s.
07-31-2016, 10:04 AM
If your tow vehicle is set up properly the 7 pin charges the camper battery from the tow vehicle ! I have traveled as much as 8 hours with the refrigerator on battery with no sign of battery discharge on the trailer.
07-31-2016, 11:00 AM
I agree. We had no drain our our tow vehicle battery. We have a three-way frig, we put it on Auto, turned it on, and it worked like a charm.
Seminole, FL
07-31-2016, 01:08 PM
You know. . I'm not sure I have a 3 way fridge.. it's a 2014 Rockwood a122s aframe. I haven't had the cover off and looked in the access panel for awhile. . I might be thinking of a previous camper.
07-31-2016, 01:16 PM
I guess I have a two way refer, gas or elect. It stays in the auto position. On gas while traveling and elect when plugged into shore power. Why is everyone scared to travel with ref on gas. Am I missing something.
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
07-31-2016, 01:23 PM
Everybody has their own phobias. We always run with the propane on but have friends who go to great lengths to NOT run with propane on. Just their phobia but it makes them feel safer and they are happy in the long run. That's what matters.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
07-31-2016, 02:43 PM
The great thing about the 3 way is you have another choice ! You people with 2 ways are limited to drive without or drive using gas.
07-31-2016, 03:11 PM
That is very true. There are occasions when I miss our pop-up and the way it could go anywhere the truck would go, but then I sit in the recliner until that passes
