Old 06-14-2013, 04:47 PM   #21
ko777's Avatar
Originally Posted by rip View Post
The OP mentioned drilling the sideways hole and drilling out the inside threads.
Lol...that's what happen when I speed read and look at pic only. Ok I will buy the nut here and hopefully find a friend that has the tool to drill the hole.
ko777 is offline   Reply With Quote
Old 06-14-2013, 06:14 PM   #22
In our Home Depot the CONNECTOR NUTs are not with the other thousands of NUTS. They were along side the THREADED STEEL RODs. Actually only the ends of the steel rods were threaded.
neil.ervin is offline   Reply With Quote
Old 06-14-2013, 06:21 PM   #23
I have an 18v Ryobi cordless drill.
#2 setting is for high speed wood drilling.
I set my drill on #1 setting for slower speed and more torque when I am cranking the tongue jack.
Old 06-14-2013, 06:56 PM   #24
Ain't this just great. 11/64" and 13mm socket sizes are both wrong.........I accept my half of the blame. But then old farts like me are permitted to be wrong.
To me, the best socket fit is 11/16" for the tongue jack and the 3/4" for the stabilizer jacks (according to only me........)
The 18mm socket fits the 1/2"x13mm connector nut more loosely than the 11/16" socket.
And the 18mm socket has a bit more tight fit on the stabilizer jack. The 3/4" socket fits the stabilizer jack perfectly.
I just want to go camping.........Wednesday: off to Lake Kachess in Washington's North Cascades.....
Old 06-14-2013, 08:22 PM   #25
Mostly Harmless
thehamguy1's Avatar
The only thing I can think is that the size of the stabilizer jack shafts is just one more thing that has changed since my A128 was new. Length, tire size, number of steps up, placement of switches, thermostat, radio...all are different now. I should get out of the advice business!
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 06-14-2013, 08:41 PM   #26
The HamGuy1
NO WAY...!!!!!!!!!!!!
I greatly value your ideas/suggestions and I think the AFrame group does too. Keep the ideas coming.
Old 06-14-2013, 08:44 PM   #27
Mostly Harmless
thehamguy1's Avatar
Well, maybe I just need more disclaimers...
2011 Rockwood A128
60W solar system
Old 06-14-2013, 10:27 PM   #28
handbuilder's Avatar
.... And there I was (blame this on Lee), standing in the aisles of Camping World holding a prepackaged socket that attaches to a drill for the stabilizers and then I stopped and reminded myself to go back and absorb this discussion and photos....and determine if I could slyly relieve my DH of one of his drills. Haha (NOT!)...for now (until then), I'll benefit with the exercise - work off the 'wind flaps' under my arms. LOL
Lee - youve got alot of A Frame experience we can all glean pearls from....disclaimers, schhhlaimers....thanks for sharing!!
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 06-14-2013, 10:37 PM   #29
Jeep4Two's Avatar
So far I just use the drill in the driveway. Not much room in the jeep for extra gear.
While I setup the DW takes care of the stabs (after I level). So no worries there. She sets up house inside while I finish hooking up power, water and set the aquatainer out for grey water.
So far the tongue jack has been fine and the quick drop during unhitching isn't a bother.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 06-16-2013, 08:50 AM   #30
ko777's Avatar
Originally Posted by thehamguy1 View Post
And I just looked at what I was calling my 3/4" socket, sure enough it's a 13mm socket. Anyway, it fits both the stabilizers and the adapter on the tongue jack, so the exact size is moot. Sorry about the misquote on the size.
Is this the correct part?http://www.princessauto.com/mobile/p...ductID=3860483
What tool did you use to drill a hole?
What is the spec of your cordless drill in the in-lb of torque?
