Old 10-18-2011, 02:38 PM   #1
Mostly Harmless
thehamguy1's Avatar
covering drains--mouseproofing
This may be unnecessary but I can always undo it: I bought two junction box covers and screwed them over the two plastic drains--the one under the heat pump and the other under the refrigerator controls area. This should help discourage rodents while my A-frame is stored elsewhere this winter. The two covers may also help keep dampness out.
photo one: drain under heat pump--before. Photo two: after.
Name:	heat pump drain.jpg
ID:	8679   Click image for larger version
Name:	plate on drain.jpg
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 10-18-2011, 08:33 PM   #2
Jeep4Two's Avatar
Glad to see that your heat pump drain is as rough looking as mine. That cover is a simple and elegant solution for outdoor storage!
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 10-19-2011, 09:27 AM   #3
Ok .. I'll bite .. as i didnt even know this drain existed ...
I have the two drains out the side .. but didnt even know about this exit point .. is this an overflow for the pan the holds the water ... or do i have something different than you guys ...
my trailer is in the shop getting some work done on it .. (warrenty) .. so i cant run out and have a look ..
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 10-19-2011, 09:50 AM   #4
Jeep4Two's Avatar
I had my A126 on the drive way after out last trip. I decided to check out wiring and look for possible mouse entry points for winterizing ?before I figured out my garage parking trick). The 'port' is under the cool cat and I can only guess that it's there for overflow issues with the condensate pan.
The Dometic manual makes no mention of the 'port' in the installation/instruction manual. I am assuming it is a factory 'mod' that was implemented to solve some sort of problem.
Slightly off topic... I was pleased with the fact that there were almost no entry points for critters. Except for this port everything on my unit was sealed pretty well. The wiring however really should be in automotive inner duct.
Jeep4Two
Old 10-19-2011, 09:51 AM   #5
Jeep4Two's Avatar
By the way Hamguy... Is the center part of you drain/port just loosely sitting in the fitting? I noticed when I was inspecting that the grill of that drain could just be lifted up, it wasn't sealed to the ring.
Jeep4Two
Old 10-20-2011, 02:53 PM   #6
Mostly Harmless
thehamguy1's Avatar
Gosh I never checked. If it IS loose that's another reason to seal off the opening when the unit will be unobserved for months.
2011 Rockwood A128
60W solar system
