Old 07-15-2013, 06:29 PM   #11
Originally Posted by rawlus View Post
You don't need a kill switch or to spend any additional money, just pull the main fuse for the power line which is about 12" from the battery box, it's in a little red flip-top weatherproof inline fuse holder, this will cut all battery power without any investment or additional devices. I've been doing this for my a frame since purchase, I put the fuse on top of the propane tank cover and have never forgotten to put it back.....
I have a 2012 A122 and do not see the fuse. Can anyone confirm their A122 has one. I even called the dealer who said he did not think it had the fuse. I'm confused.
Tinsu is offline   Reply With Quote
Old 07-15-2013, 06:31 PM   #12
Mine is a 2011 and def has the in-line fuse.
2011 A-122
rawlus is offline   Reply With Quote
Old 07-15-2013, 06:32 PM   #13
Originally Posted by herk7769 View Post
A battery kill switch is needed and not supplied with our campers. Without one you can expect a fully charged battery to be dead flat in 10 days.
Always use a battery tender (solar or plug in) to maintain your battery, install a disconnect, or remove the ground cable (only) every time you put it away.
I assume the ground cable is black? My tech guy at dealership said to remove the red cable? I doublechecked he said that. Any thoughts on why he picked the red cable?
Old 07-15-2013, 06:34 PM   #14
The dealership guy told me he was surprised to learn Rockwood did not put them in 2012 units.
Old 07-15-2013, 07:28 PM   #15
My 2014 does not have an inline fuse. It has a circuit breaker instead.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 07-15-2013, 07:33 PM   #16
Much easier to install a cutoff switch.
I mounted a household light switch above the battery, so it is an easy flip of the finger to turn the power on/off.
bakken is offline   Reply With Quote
Old 07-15-2013, 07:53 PM   #17
Fulltime family RVer
Battery disconnect-
http://learntorv.blogspot.com/2013/0...installed.html
My battery is under a floor and required screws to be removed to get at it.
ependydad is online now   Reply With Quote
Old 07-15-2013, 08:02 PM   #18
Originally Posted by Jsusluvsyou View Post
Just bought a122 BH and been out in it twice. Parked it at home and just opened it up, tried to turn on the interior light and it wouldn't. Wondered if something drains the battery? Thought everything is off, as far as I know. How can you tell how much is left in the batteries?
You can buy a battery load tester and test the battery yourself to find out if you have a good battery or take it into any auto parts store and they will test it for you. I have a actron 130 amp heavy duty battery load tester which cost me something like $50.00 and will test the battery in 10 seconds and will tell you the condition of your battery.
Cacooze is offline   Reply With Quote
Old 07-15-2013, 10:47 PM   #19
Really? Where is it located?
Old 07-16-2013, 03:17 AM   #20
Jsusluvsyou's Avatar
I have. 2014 a122bh can I turn battery off by the circuit breaker?
Jsusluvsyou is offline   Reply With Quote
