07-15-2013, 04:03 AM
Dead Battery
Just bought a122 BH and been out in it twice. Parked it at home and just opened it up, tried to turn on the interior light and it wouldn't. Wondered if something drains the battery? Thought everything is off, as far as I know. How can you tell how much is left in the batteries?
07-15-2013, 06:09 AM
There are several loads on your battery that cannot be turned off. Most prominently is the propane leak detector. It alone will drain the battery to death over a period of a few months. Another is the phantom load from the stereo, but that is likely a much lower draw. During storage the camper should either be plugged in or the battery disconnected.
Full discharge can damage or destroy a battery. Disconnect the battery from the camper and put it on a stand alone charger to see if it will take and hold a charge. Then go from there.
Here are 2 links to a primer on living with a 12V electrical system. It is written to cover big RVs, but is applicable to A frames too.
The 12volt Side of Life (Part 1)
The 12volt Side of Life Part 2
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
07-15-2013, 06:47 AM
A battery kill switch is needed and not supplied with our campers. Without one you can expect a fully charged battery to be dead flat in 10 days.
Always use a battery tender (solar or plug in) to maintain your battery, install a disconnect, or remove the ground cable (only) every time you put it away.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
07-15-2013, 08:21 AM
Agree with above two posters ... always maintain your battery by either plugging it in when you get home, disconnect, or get a solar maintainer ... however i really dont know how well they work. I just plug mine in when i get home .. and leave it plugged until the next trip ..
Something you should look at over and above this is the cut off switch underneath the sink side of the front roof system. It could have lost its connection, and will cause the same problem .. no lights. I you strip back the valance ... you will see it .. give the wires a little wiggle and press the switch a couple of times ... this is the likely culprit.
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
07-15-2013, 08:37 AM
Any particular reason? I do both + & - but I guess that is just a habit once changed would save half the time spent disconnecting.
2021 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
07-15-2013, 12:08 PM
My favorite reason.
Get it backwards JUST ONCE and you will only take one off for ever more.
07-15-2013, 12:13 PM
My favorite reason.
That's great, Lou. Should be a sig line.
2011 Flagstaff 831 RLBSS
07-15-2013, 12:23 PM
Peace!
Dan & Rita D
07-15-2013, 02:58 PM
My favorite reason.
Thanks. Can't say that I have ever done that but I sure have done lots of things wrong 1st.
07-15-2013, 05:51 PM
You don't need a kill switch or to spend any additional money, just pull the main fuse for the power line which is about 12" from the battery box, it's in a little red flip-top weatherproof inline fuse holder, this will cut all battery power without any investment or additional devices. I've been doing this for my a frame since purchase, I put the fuse on top of the propane tank cover and have never forgotten to put it back.....
2011 A-122
07-15-2013, 06:29 PM
I have a 2012 A122 and do not see the fuse. Can anyone confirm their A122 has one. I even called the dealer who said he did not think it had the fuse. I'm confused.
07-15-2013, 06:31 PM
Mine is a 2011 and def has the in-line fuse.
2011 A-122
07-15-2013, 06:32 PM
I assume the ground cable is black? My tech guy at dealership said to remove the red cable? I doublechecked he said that. Any thoughts on why he picked the red cable?
07-15-2013, 06:34 PM
The dealership guy told me he was surprised to learn Rockwood did not put them in 2012 units.
07-15-2013, 07:28 PM
My 2014 does not have an inline fuse. It has a circuit breaker instead.
Tom
2012 Rockwood A122S
07-15-2013, 07:33 PM
Much easier to install a cutoff switch.
I mounted a household light switch above the battery, so it is an easy flip of the finger to turn the power on/off.
07-15-2013, 07:53 PM
Always Learning
Battery disconnect-
http://learntorv.blogspot.com/2013/0...installed.html
My battery is under a floor and required screws to be removed to get at it.
07-15-2013, 08:02 PM
You can buy a battery load tester and test the battery yourself to find out if you have a good battery or take it into any auto parts store and they will test it for you. I have a actron 130 amp heavy duty battery load tester which cost me something like $50.00 and will test the battery in 10 seconds and will tell you the condition of your battery.
07-15-2013, 10:47 PM
Really? Where is it located?
07-16-2013, 03:17 AM
I have. 2014 a122bh can I turn battery off by the circuit breaker?
