Old 08-22-2012, 10:09 AM   #1
Digital thermostat
I did a search and didn't find the answer. Has anyone swapped their analog thermostat (2011 A122 with cool cat) with a honeywell digital programmable unit.
toleworks is offline   Reply With Quote
Old 08-22-2012, 11:51 AM   #2
DGrissom's Avatar
There is an older thread on this subject.
Hardside A-Frame and thermostat upgrade
I think the final consensus is that it was not feasible to buy a new type digital thermostat (same type as those used on 2012 + models). The inner workings of the older Cool Cats were not compatible with the newer digital units.
I believe that someone was going to try to buy an off the shelf digital thermostat (like used in the home and possibly RV's) and try it. I don't recall if anyone ever actually did this and followed up in any posts.
David and Jo Ann G. (& Kenzie the Sheltie)
Prattville, Alabama
2018 Flagstaff E-Pro 19FD "Phoebe" 18 Nights!
2012 Rockwood A128S "Rocko" 200+ Nights!
Nights Camped 2012 - 2017 = 226
Nights Camped 2018 = 0 as of today)
DGrissom is offline   Reply With Quote
Old 08-22-2012, 12:21 PM   #3
The most common sway is using a Hunter Douglas t'stat found at places like WalMart for around 20 dollars plus the addition of a sub miniture SPST switch from Radio Shack. The HD thermostat uses 2 AA batteries for it's power source. There are wiring instructions online for both Coleman/Atwood and Dometic AC units. Something different than that and you would probably have to do some experimenting to get it right.
Old 08-22-2012, 10:38 PM   #4
Jeep4Two's Avatar
I'll confirm that the domestic thermostat (digital) won't work on the 2011's. That is based on a call to Dometic. There is a different control system used in the cool cat.
Not sure on the Hunter Douglas solution with our aframes. I'd be Interested to see a home that manages a solution that works.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
