Old 06-22-2015, 02:36 PM   #11
not only does mine lean, but it sometimes spins when i try to get back into it after a long day of staring at the campfire and hydrating myself
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is online now   Reply With Quote
Old 06-22-2015, 03:24 PM   #12
satdog01's Avatar
Rotate unit 180 degrees and see if it still leans
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 204 nights as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
....2014 = 39, 15 = 52, 16 = 77, 17 = 81, 2018 = 4
Retired :
satdog01 is offline   Reply With Quote
Old 06-22-2015, 03:32 PM   #13
Ford Idaho's Avatar
Does your trailer lean?
Depends on if I am standing outside or sitting inside.
If inside yes it does lean......
Old 06-22-2015, 04:56 PM   #14
Georgia Frog Rally 2018
aceinspp's Avatar
We use 2 2x8 4ft long boards to usually put on the side that leaned. The length will get both wheels on the boards with some to spare so you can move forward or back some. We found out on our first V-light that this was a problem most of the time leaning and also cause the bath door to not close till we got it leveled out.
With our new V-light we usually do not have that problem do to the 3rd slide out, but we still carry the boards just in case. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-22-2015, 05:11 PM   #15
no spring shackles .. on this unit ..
please pay attention to the forum name ... seriously .. because alot of misinformation can delivered from those who have other units
answer to the original post ... no ... not even slightly ..
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 06-22-2015, 05:13 PM   #16
mark0224's Avatar
When I set up my v lite I set it up so its 1/2 a bubble off and when I put the slides out it ends up right on level.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 06-22-2015, 05:18 PM   #17
x2..Harkerr!
2011 Flagstaff V-Lite 30 WRLS
2007 F250 SD
chasbo70 is offline   Reply With Quote
Old 06-22-2015, 07:52 PM   #18
I have an A122S, and I think the driver's side with the appliances is always a bit lower. I don't really notice it that much when I tow, but when I setup in campgrounds, I always have to put the wheel on that side on a leveling block to get it level.
It's important to me that this side be level or a bit higher than the door side, as this is the side of the A frame that my head rests against when I sleep!
2015 A122S "The next campsite tour of this type of intriguing camper will begin in approximately 15 minutes. We ask that you refrain from any flash photography as it tends to wake the native inhabitants..."
Camped 6 times in 2014, 5 times so for in 2015
underwhirled is offline   Reply With Quote
Old 06-22-2015, 08:53 PM   #19
Just measured my camper. The height of the trim just above the center of the hub is the same on both sides. 21 14/16.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 06-23-2015, 02:31 PM   #20
Originally Posted by Harkerr View Post
Check your spring shackles carefully
Torsion suspension.
99 4runner
T12BH Aframe
68Triumph is offline   Reply With Quote
trailer
