Old 06-23-2015, 02:52 PM   #21
Boss Ox & Drovergirl
oxcamper's Avatar
Does your trailer lean?
Only when it drinks too much
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 06-23-2015, 03:00 PM   #22
youroo-- where did you get those wedges, and is there a trick to using them?
pacin is offline   Reply With Quote
Old 06-23-2015, 07:27 PM   #23
Dose your world lean?
Originally Posted by Loranimal View Post
So I get my toy home and put it the garage because I wanted to Eternabond the skylights (whole other story) and notice the trailer leans on the drivers side about 3/4 - 1". I realize most the equipment is on that side, but that seems like a lot. I was going to lift it a little so I guess I will add an extra inch to that side.
Anyone have leaning issues?
Carl
There was a post in a different listing about someone having a toy box about 2 yrs old and his springs went flat!, you did not say the age or mileage but since you have it in the garage anyway look at the springs before you jack it up and see what they look like.
If on the newer side you might just need to have a spring shop add a leaf or two to level the coach out, since most of the heavy items are on that side.
Good luck and Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 06-24-2015, 05:30 AM   #24
handbuilder's Avatar
The post came from the A-Frame subforum. We are discussing a very small trailer here...not one with slides or extreme weight.
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is online now   Reply With Quote
Old 06-24-2015, 06:24 AM   #25
No (Trick) at all can be used on (Signal or Dual wheel setup) Just place Ramp in front of tire and Drive up on ramp/ STOP/ place other ramp behind other tire/release brake and let tires equalize between ramps/DONE! Amount you go up the 1st ramp will determine the (Amount of Lift)! They are (Magnum 16000#/4ton set/ramps) Made in the USA! Harbor Freight# 67722 I attached plywood on the bottom to be able to use is them in (Soft soil/Stone/Gravel) situations also! We have (Stacked wood/Lego type plastic blocks/Ect) this works Very Easy for Us,Your situation may very? The ramps are Light weight also! Youroo!!
Old 06-24-2015, 06:42 AM   #26
Back to the original question. The axle manual doesn't mention any adjustment options. But the Al-Ko axle does have a two year warranty. So if your camper is within that time, I'd start a warranty claim by having the camper inspected by an Al-Ko repair facility. Call Al-Ko at 574-294-6651.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 06-24-2015, 09:13 AM   #27
Thanks for all the replies. I am just talking about a A-Frame type trailer. It does not have springs, it has the torsion axle. Also the trailer is sitting unhitched in my garage, leaning towards the drivers side. I will take it to work and weigh each side to compare.
Carl
Loranimal is offline   Reply With Quote
Old 07-07-2015, 04:38 PM   #28
Rockwood Premier A126
gregory's Avatar
Carl,
Did you ever weigh it?
Do you have water in the holding tank? That might cause a 'lean' effect.
After all the various replies I've forgotten...how far off does it lean... measurement wise?
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
trailer
