Old 02-04-2016, 05:34 PM   #1
mikeandclay's Avatar
Dometic ac problem
Was hoping to trouble shoot before I call for repair. On our first trip out and the thermostat on the Dometic a/c isn't working right. The display is flashing and nothing happens. Any suggestions?
Thanks!
mikeandclay is offline   Reply With Quote
Old 02-04-2016, 06:09 PM   #2
Head Rambler
It's most likely going to have to be replaced, but have you tried to remove all power, 12 & 120 volts and see if it clears up?
Is it showing any error codes, or just flashing the display?
Gotta go campin!
Old 02-04-2016, 06:20 PM   #3
It's tough to tell what it's reading - looks like an E and maybe I. I'll unplug everything and see if that works.
Ugh if it has to be replaced... This is the maiden voyage!
Old 02-04-2016, 06:20 PM   #4
The "E" is flashing.
Old 02-04-2016, 06:25 PM   #5
fonzie's Avatar
This might help....
A/C error code E1
Fonzie
Old 02-05-2016, 09:31 AM   #6
Head Rambler
Remove both 12 and 120 volt power and see if that resets it. Maybe that'll work and you won't have to take for service.
Gotta go campin!
Old 02-05-2016, 10:02 AM   #7
1A Camper's Avatar
When we picked up our A frame the deal show us how to reset the controller. It was either the power ( sel) button and the + or the - at the same time.
I would also try removing the power.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 02-06-2016, 06:12 PM   #8
Thanks for the help and suggestions. I called the dealer yesterday and they talked me through all the resets which didn't work. Disconnecting the power didn't work either, so making an appointment when we get home. I'm just really glad I picked up a space heater at target on a whim!
dometic
