Old 05-27-2013, 09:53 AM   #1
Jeep4Two's Avatar
Drain or dont drain H/W heater
Just curious what the community here does with their hot water heater between trips.
Do you drain or not drain between camping trips?
I've seen some folks at the CG packing up and draining their heater, but since our heaters don't have a drain valve it seems to be a lot of effort.
Any benefit one way or the other?
It would seem that an empty tank with residual water wouldn't allow the anode to do its job.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 05-27-2013, 09:56 AM   #2
Hi, I drain mine after every trip and drain out the system. We get lots of mineral build up from the water where I live.
desertwilde is offline   Reply With Quote
Old 05-27-2013, 10:00 AM   #3
I forgot to add that while there is no drain valve, there is a rather large nut attached to the heating element that is where to drain it from. Be advised that once that is loosened it will come out under a feed deal of pressure. Do not stand in front of it.
Old 05-27-2013, 10:09 AM   #4
I drain mine everytime. I don't want that weight working against the WH mounting while I drive.
Atwood has a 1/2" drain plug that I remove (and then screw a short piece of 1/2" PVC into it to allow me to direct the water into my sewer hose as the last step at the dump station).
Old 05-27-2013, 10:58 AM   #5
MtnGuy's Avatar
I just drain mine once a year for winter. No problems, and I still have about 75% of my anode rod left after 5 years.
Old 05-27-2013, 11:14 AM   #6
Oakman's Avatar
The only time I drain is at the end of the season when I winterize the fifth wheel. I've been doing this for 10 years without any issues.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-27-2013, 11:25 AM   #7
Denver, CO
garbonz's Avatar
X2.
But I'm sure that anode use depends on the water in your area, so you may need to check more often. Experiance will tell.
I don't winterize (heated shed) but do drain the HW tank every fall and leave it empty over the winter.
2017 Fuse 23T
Old 05-27-2013, 12:06 PM   #8
bob213's Avatar
The less times I unscrew the anode rod the less chance I have of cross theading it when I put it back in. (I have that "special knack" for things like that.) I drain mine at the end of the season and replace the anode rode when I do unless it's in really good shape. I do have low point drains on both sides of TT and it seems like one must get some water out of the water heater as It has to refill the next time I use it. I do drain those if the TT is going to sit for more than 2 weeks.
bob213 is online now   Reply With Quote
Old 05-27-2013, 12:55 PM   #9
DDC
DDC's Avatar
I only drain it for winter too, can't see any reason for continuously doing this.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is online now   Reply With Quote
Old 05-27-2013, 03:45 PM   #10
i drain for winter only too .. no need for allthe fuss .. especially like bob213 says .. crossthreading this little beast would instantly put a hamper on your happy.
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
