Old 07-04-2016, 08:33 AM   #1
mollypcb's Avatar
Draining water tank?
We have been draining our water tank after each trip, but about an inch and a half always remains in the tank. What are we doing wrong?
Molly
Flagstaff T12BH A-Frame 2016
2006 Toyota Tacoma 4X4
mollypcb is offline   Reply With Quote
Old 07-04-2016, 08:37 AM   #2
Are you level when you drain it? To get all of it out you might have to be lower on the drain side.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-04-2016, 08:41 AM   #3
Ford Idaho's Avatar
Nothing!
If you what to get more out you can try lifting one side, but I doubt it will be worth the effort.
Old 07-04-2016, 10:31 AM   #4
I lift one side and get most out but not all.
2012 Rockwood a124
mzak is offline   Reply With Quote
Old 07-04-2016, 10:38 AM   #5
Oakman's Avatar
I always leave the fresh water drain valve open on the ride home. It gets most (not all) of the remainder out.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-04-2016, 10:45 AM   #6
Witch Doctor's Avatar
Your not doing anything wrong, If your worried about stale water just add a little bleach or sweet water when you refill. most drain valves are on the side about a 1/2 to 1" above the bottom, I know mine is it is not on the bottom....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 07-04-2016, 11:17 AM   #7
raspivey's Avatar
I was pleasantly surprised to find that my new one has about a 4" sqaure "sump" area that extends below the tank and through the belly pan. I can get all but about 8 oz. out of this one.
Old 07-04-2016, 11:36 AM   #8
mollypcb's Avatar
Thanks for the help. We feel better now, but it creates a new question about that much water in the tank over the winter. We are new to this and haven't been through the winterization process. I know there is a lot of great information on the forum so I guess I better look it all up...
Molly
Old 07-04-2016, 11:41 AM   #9
Ford Idaho's Avatar
There is plenty of room in the tank for freezing water to expand without breaking anything.
The water lines is where the issues are.
Using air and/or antifreeze for the lines is what must be done.
Old 07-04-2016, 12:16 PM   #10
Flybob's Avatar
I leave the FW tank drain open. That way of moving around inside while winterizing causes some of the remaining water to go down the drain line it will not freeze. You can put an old sock of similar item over the end of you are worried about bugs getting in.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
drain, tank, water, water tank
