Old 09-28-2016, 07:23 AM   #21
jeff
jeff64's Avatar
I've seen a fair amount of floaties in the water at the SP we frequent and some degree of discoloration. Therefore, any water going into the tank goes through a filter first. I did remove the FR system and use a whole house filter with a 10 micron carbon, taste odor and sediment filter and have done so for the last 10 yrs. Works for me. We do make coffee with it, etc.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-28-2016, 07:51 AM   #22
I use these filters to save my plumbing. often sediments and such get into the water. These sediments can get trapped by your faucets ruining the seats and or modules. I once spent the better part of a day trying to remove the cartridge from a moen faucet. Basically the filters help to keep other plumbing from getting ruined.
tdiller is offline   Reply With Quote
Old 09-28-2016, 01:55 PM   #23
Even in Canada , i use bottled water . ...never drink campsite stuff....but its run through the system for dishes and cleaning. No filter no issues.... cause there is no filter cartridges .
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 09-28-2016, 02:11 PM   #24
BamaBob's Avatar
We have a external 2 stage filter (Sediment & .5 Micron Carbon) between the water pedestal and our coach which then passes through a water softener and then through the whole house filter on the coach (which we happily let Forest River change every year at Goshen )
The Sed filter gets changed every 3-ish months and often it is full of gunk (depending on where we have camped) The carbon filter can last up to 6 months - again depending on where we have camped.
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 09-28-2016, 02:14 PM   #25
i took my filter out after i noticed it was not tight could have leaked.
Not long after I discovered issues with sediment clogging the intake to the toliet.
I use a filter all the time now. Nothing like meeting new people while you pull the toilet out of your rig.
2015 Ram 2500 4x4 6.4l with 2015 Flagstaff 21FBRS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 09-28-2016, 03:12 PM   #26
BamaBob's Avatar
On a lot of campers, you must use the supplied filter wrench to correctly tighten the whole house filter. The filter wrench will allow you to tighten the filter (it actually goes over a anti-reverse notch) that prevents the filter from unscrewing due to road vibration.
