Old 05-19-2016, 08:39 AM   #1
Mountain Girl's Avatar
Exit Window is stuck.
We have been trying to open the window over the sink which is the Exit window. Our camper is a 2016 Flagstaff T19QBHW. We've had it open once or twice. Help please!
Mountain Girl is offline   Reply With Quote
Old 05-19-2016, 08:43 AM   #2
B and B's Avatar
Hello,
I find the seal is pretty sticky after sitting. I just hit the end of handle with my hand to break it free if it has one of those or remove the screen and push a corner while unlatched.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-19-2016, 08:44 AM   #3
Mine is also difficult to open, although the screen moves easily. I lubed the window track with some silicone spray, which helped a little, but I still have to hank hard to get the window open. I think it has to do with how the window frame was installed. It may be a bit out of alignment.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 05-19-2016, 08:50 AM   #4
RSchleder's Avatar
I have had several of the emergency windows leak after opening them many times. It's like the long "bar handle" doesn't put enough pressure to seal the window against the rubber seal. So typically, we don't open ours very often.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-19-2016, 08:53 AM   #5
VinceU's Avatar
Use a hairdryer to warm the glass and gasket. Follow with gentle persuasion, tapping.
Old 05-19-2016, 09:22 AM   #6
Maybe if it's a bit of a twist in the wall alignment the window binds up. Try to unhook one roof lock or the other, maybe even both with someone holding the wall up and try the window.
You never know what you know until you ask someone!
timfuji is offline   Reply With Quote
Old 05-19-2016, 11:02 AM   #7
mudman2's Avatar
I've had that problem since I got the unit. The last time I had to remove the screen than work at it for awhile. I'm sure if I had to depend on this as an emergency exit , we'd all be gonners
2015 t19qbhw
2015 Toyota Tundra crewmax lmtd
2019 microlite 25bds
2015 tundra
mudman2 is offline   Reply With Quote
Old 05-19-2016, 11:57 AM   #8
mdstudey's Avatar
2015 t19qbhw
X2, plus the long handle is not easy with arthritic hands.
Chuck & Denise + Pata a.k.a the cg Gladys Karvitz
He is a Master Naturalist She is a quilter and RV Guru
2
008 Dodge Ram 2500 TX Edition2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights2018 The great adventure planned and will be rolling soon.
mdstudey is offline   Reply With Quote
Old 05-19-2016, 02:52 PM   #9
Butch Wilson's Avatar
We had our A frame t21QBHW at Hatteras last week ! The large window was stuck . We had one person on the inside tugging and one on the outside pushing until it finally opened. Once opened sprayed the gasket with silicone spray, glides like a dream now ! Good luck, it was not easy !
Butch Wilson is offline   Reply With Quote
Old 05-19-2016, 07:26 PM   #10
Thank you for your advise. My husband and I will try it again. I accidentally broke something that was sliding up the side but, it still didn't open. Makes you wonder if you really needed out???
