Old 07-21-2015, 08:14 AM   #1
Extra Deep Cycle battery?
I was thinking about mounting another battery on my A122BH. Has anyone else done this?
God Bless!
smurf is offline   Reply With Quote
Old 07-21-2015, 08:38 AM   #2
Yes...I mounted two 6 volt deep cycle golf cart batteries enclosed in plastic battery boxes. Since you already have a 12v battery, try to add another of similar age and capacity to prevent one from leaching voltage from the other.
Adds a bit of weight to the tongue but works well for an extra couple of days dry camping. I also added a battery disconnect switch to help isolate the batteries while not using the camper.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 07-21-2015, 09:32 AM   #3
There are lots of threads on here that talk about this, but replacing the 12 volt with two 6 volt gc batteries run in parallel is the best upgrade I've done. I have dry camped for 5 days running the lights, fan, and water pump without a problem.
kinnikinnick is offline   Reply With Quote
Old 07-21-2015, 09:36 AM   #4
In parallel?......that's still only 6 volts....in series that's 12 volt
Trevor43 is offline   Reply With Quote
Old 07-21-2015, 02:36 PM   #5
I had a second battery (12V size 24) added as part of the delivery of my A122. My goal was to get 4 days/3 nights of dry camping using heater as needed in the Colorado Rockies (batteries staying above 50%). So far, batteries have done 2 cold nights (high 20s) dry camping without issue.
An extra long battery box was added (replaced the standard single battery box) to just fit within the a-frame portion of the trailer tongue frame. It barely holds 2 size 24 batteries. I have added a marine dual battery selector/shut-off switch to avoid disconnecting battery cables while storing the unit.
Fred W
2014 Rockwood A122 (no s or h)
2008 Hyundai Entourage (minivan)
camping Colorado and adjacent states one weekend at a time
pgandw is offline   Reply With Quote
Old 07-21-2015, 04:54 PM   #6
Sorry, got my series and parallel mixed up. My batteries are rated at 235 amp hours, which of course I can't use all unless I want to kill my batteries. Pretty satisfied so far.
Old 07-21-2015, 11:03 PM   #7
DanM-AZ's Avatar
Yes. I built a custom battery box and mounted a very large 12V battery. Described here:
http://www.forestriverforums.com/for...rum-81229.html
I am about to mount two 100 watt solar panels on the front slope. I will post details once done ....
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
DanM-AZ is offline   Reply With Quote
Old 07-22-2015, 03:35 AM   #8
235 amp hours......I bet you are a "happy camper".
battery
