Old 05-05-2018, 02:17 PM   #1
lastayt's Avatar
Fan kit placement for fridge
I have just ordered the fan kit 2 NORCOLD DOMETIC RV cooling Fan Kit ON/OFF Thermostat, Wires Hardware from Ebay. The instructions show one fan on the bottom blowing in and one at the top blowing out. Many pictures I’ve seen of this fix show both fans at the top of the fridge compartment and wonder where the best locations are.
Those of you that have put fans in the fridge compartment, what do you think is the best placement and why. Also is it better to place them blowing the hot air out the vents or blowing in onto the fins?
Thanks! We leave for a 30 day trip the 15th and hope this fixes our fridge problems. We live in AZ and keeping the fridge a decent temp is a chore!
Laurie Stayton
Rockwood A213HW
2016 Ram 1500
lastayt is offline   Reply With Quote
Old 05-05-2018, 02:22 PM   #2
I put my fan at the top of coil, was not enough room at the bottom.
Has worked fine now for almost a year now.
2017 Rockwood A213HW
2017 Chevy Colorado Z71 4x4 V6
backpacker3 is offline   Reply With Quote
Old 05-05-2018, 02:35 PM   #3
World Traveler Member
abdiver's Avatar
I installed one on top blowing out and I hooked it to the refrigerator DC connector that I never use and ran a micro switch inside by the stove to turn on manually as needed. The air flow on these A frames refrigerators is poor and the inside temps vary a LOT. I also monitor the inside with a wireless temp gauge and try to keep the temps between 40 and 50 degrees.
2014 A194HW
2004 Toyota 4runner V8 4WD
abdiver is offline   Reply With Quote
Old 05-05-2018, 07:05 PM   #4
MontyPP's Avatar
Just as an FYI the fridge temps should br in the 38 to 41 degree range to keep spoilage from happening.
I installed my fan at the top blowing out. I also used Reflectic to close up a bunch of the gaps around the fridge.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
2016 Nissan Frontier Crew Cab
Flagstaff T21TBHW
MontyPP is online now   Reply With Quote
Old 05-05-2018, 10:41 PM   #5
The problem with the airflow for the A-frame fridges is that the hot air will not necessarily exhaust easily (or at all). There are several reasons for this:
1) The top of the fridge compartment is not sealed off to the top of the vent, leaving a space for hot air to collect. Same with the sides of the fridge compartment.
2. The baffle between the upper and lower vent is poorly mounted and actually blocks the air flow rather than pushing it through the cooling fins.
3. The vents themselves are poorly designed, having a lot of resistance to natural air flow in the name of keeping out water. My old Coleman PUP had metal vent covers that did a lot better job of promoting air flow - no fan needed - but would occasionally let in a little water in a thunderstorm.
A fan pushing air out the top vent is the direct solution. I also added Reflectix to help direct the air flow to the top vent. After advice from others, I tie-wrapped a 12V computer case fan directly to the vent cover. With that single fan that draws 70ma (.07A), I can decrease the propane or AC setting by about 50%. The fridge cools very reliably and efficiently.
just my experiences
Fred W
2014 Rockwood A122 A-frame
Old 05-06-2018, 09:58 AM   #6
Another "top blowing out"
I mounted my computer fan to the inside of the top vent for efficiency.
I wired in a series toggle switch to operate from the outside of the vent.
The fan has a blue led light that is visible in dim/dark conditions. Cool...
It does make a difference in hot temps.
mickrock is offline   Reply With Quote
Old 05-06-2018, 07:55 PM   #7
We bought the exact same kit. We put both fans on the top blowing out. We were not sure if putting one on the bottom would interfere with the flame. So we just put both on top.
2018 A213HW
2018 Chevrolet Colorado with tow package
lcangler is offline   Reply With Quote
Old 05-06-2018, 09:10 PM   #8
How noisy are these fans, and would they work in my Georgetown do you think? My fridge is in the slideout (don't know what difference that makes but they tell me that is why it has a fan. I hate it. It sounds like a jet taking off right outside my window. Talk about a way to ruin a nice quiet camping trip! If a computer fan would work that would be great as they certainly seem quiet enough.
Sandy B is offline   Reply With Quote
Old 05-06-2018, 10:59 PM   #9
MontyPP's Avatar
Computer fans are really quiet and not only take the heat but are long lasting. I have the kit with a single fan but the doubles are also quiet. I have to take the top vent off to see if mine is working.
Flagstaff T21TBHW
Old 05-07-2018, 06:12 PM   #10
lastayt's Avatar
Thanks everybody for the info. I love this group! A great bunch of people! I will have to write after our trip and let you all know how this fix worked. The fridge has been a thorn in our sides and hope this hack is as good as it sounds. The AZ heat is h*** on these Aframe fridges. Have a wonderful camping season!!!
fan, fridge
