Old 05-10-2015, 07:24 AM   #11
kdot's Avatar
Lights
It would help to know what camper you are writing about. If it is an A-frame, then the comments above should guide you to that little switch which may be stuck in the "in" position. If it is, you won't be able to turn your lights on at the switch on the lights.
Kent
2017 RPod179
2016 Honda Pilot
kdot is offline   Reply With Quote
Old 05-10-2015, 06:01 PM   #12
Since you are delving into electrical stuff oldhudson, here is the list of fuses and what they control, take from a 2012 model.
1. 10 Amp Water Pump
2. 10 Amp Air-conditioner shuts off
3. 15 Amp Propane detector, Water heater, Furnace
4. 10 Amp Inside lights
5. 20 Amp Fridge
6. 30 Amp Main battery With this pulled and the camper unplugged, nothing inside worked off the battery. This was the only fuse that shut off the stereo and the nightlight. With the camper plugged in, there is no effect.
7 40 Amp is marked as reverse battery polarity protection.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
flagstaff
