Old 05-08-2015, 07:16 PM   #1
Flagstaff 21QBHW (newbi issues)
First post, haven't camped since about 1990. We just purchased a new
A frame unit from the RV this past winter. Got it home in the rain yesterday and set it up today....and that's where I found my first problem. The exterior lights e.g., the one by the door work but neither of the lights mounted on the roof panel nor the roof fan work.
So I'm one of you experienced travelers can point me to the Happy Trail of RVing. Thanks for reading.
oldhudson45 is offline   Reply With Quote
Old 05-08-2015, 07:41 PM   #2
handbuilder's Avatar
Check your fuses?
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 05-08-2015, 07:46 PM   #3
check front left wiring on unit it has safety plug that control interior lamps and possible fan also/this is on left side on front behind fabric cover on torsion bars/but I have a a122s yours could be at a different location
2014 A122s rockwood 2014 jeep grand Cherokee v6 290 hp 4by4
ridgeline1 is offline   Reply With Quote
Old 05-08-2015, 08:06 PM   #4
RedLdr1's Avatar
If it isn't loose wiring as Ridgeline1 mentioned checking the fuses is next. See Here for a complete list of fuses in your T21. Number 4 is the inside lights.
If that doesn't work post again and I'll look around in our T21 for anything else that might do it...
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is online now   Reply With Quote
Old 05-08-2015, 08:32 PM   #5
Thanks for your quick replies. I did check most of the fuses, a couple seemed really stuck in place. I think I'll wait for a new day before checking it again.
Old 05-09-2015, 12:37 AM   #6
1A Camper's Avatar
What Ridgeline1 said, there is a switch that turn off the power to the roof when down. drive side front corner by the hinge.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 05-09-2015, 07:42 AM   #7
kdot's Avatar
lights
When you open the door to the camper, in the right-hand corner , under the upholstery fabric that hangs down, there is a little switch. I think it is white in color. It is just a simple little push in and out thing that closes when you drop the roof. Mine was stuck also. All that was required to fix it was to push it in and let it come back out a few times so it could loosen up. It's the same kind of switch that controls the interior light on some refrigerators and car doors.
Easy fix! Happy camping!
2017 RPod179
2016 Honda Pilot
kdot is offline   Reply With Quote
Old 05-09-2015, 06:21 PM   #8
Thanks to everyone who took time to support me in this project. As a couple of you suggested it was the switched in the corner, stuck in the closed position. Thanks to you it was a real simple fix. Everything else seemed to work fine so we will be heading out soon.
Old 05-09-2015, 08:17 PM   #9
good luck/ejoy camping
Old 05-10-2015, 01:21 AM   #10
Tom48's Avatar
My ceiling lights have be ON at the fixture before they can be turned on at the switch.
Does the fan have ceiling and fixture switch?
Tom48 is offline   Reply With Quote
flagstaff
