Old 07-15-2013, 12:01 PM   #11
Jeep4Two's Avatar
I don't think the mfg specifically monitors this forum. I do agree that it would be good consumer research on their part.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 07-16-2013, 07:37 AM   #12
jjdcamper's Avatar
Well, I finally had to contact the owner of the dealership to get some sort of response. He was quite terse in his emails and told me all about how warranties work. He cannot fix anything that's under warranty without Forest River's consent. FR requires pictures of the malfunctioning part and a full description from the dealer, not me, before they will consent to a repair. I have to take the camper back to the dealer and no doubt leave it there until it can be fixed. My estimate is, it will probably take two to three weeks before I hear from them once I take the camper back. Great, right in the middle of camping season! It's funny how quick the dealers are to take your money for the purchase but so slow to react if anything goes wrong. And to top it off, the dealer is a two hour trip, each way, for me. If I didn't know better, I'd start looking for labels that say, Made in China! It wouldn't surprise me to find out the A/C units are made in China and shipped to FR. Or and other appliance in the camper. I'm beginning to think I bought a pig in the poke. Is there anyone out there who has a 2013 T12RB Flagstaff A Frame that hasn't had any trouble with their camper at all? I'd be interested to know.
Disgruntled Jim
jjdcamper is offline   Reply With Quote
Old 07-16-2013, 08:03 AM   #13
Fulltime family RVer
Not an aframe for me, but *all* new campers have some level of issues. It's a fact of life. When you think of them as a "home on wheels" and liken it to a new build- it's not a whole lot different. I had a house built in '99 and we had a similar list of fix-it issues. In fact, the builder had 1-week, 1-month and 1-year check-ins prescheduled and planned for.
But, I digress- my real comment had to do with leaving the camper to get the diagnosis and then repair. If your camper is essentially usable, you could try and schedule time with your dealer to have the documentation part done. Should only take a few hours. Drive up for that, get them to take pictures and whatnot and then take it home and use it until they're ready to fix it and then drag it back up.
I did that with my camper. Had it in and then went straight from the dealer for 3 weeks of camping and then took it back for the work to begin.
I hear you on the 2 hours away- my dealer is about 2 1/2 away (and they were even the 2nd closest dealer to me).
ependydad is online now   Reply With Quote
Old 07-16-2013, 08:34 AM   #14
jjdcamper's Avatar
The camper, as it stands, is not really usable. It has no A/C at all and the ceiling fan won't cool it down, it just draws in air from outside. I live in South Carolina and right now, it's in the mid 90's to high 90's for the rest of the summer. So, the camper is not usable and I might as well leave it at the dealer until he gets the A/C fixed. Without the A/C, I wouldn't go camping anyway. I can take 80 degree weather but the 90's is a different story. At 9:00 o'clock this morning, it was 81 in the camper. By noon, it will be 90. But thanks for your reply. I appreciate it.
Jim
Old 07-16-2013, 08:38 AM   #15
Craptastic. I hear you, though. If I can't be cool when I sleep, I can't sleep.
Good luck. :-(
Old 07-16-2013, 08:38 AM   #16
I learned from owning a pop up that that light and cheap campers are lightly and cheaply built. And are relatively high maintenance. Yet I returned to buy another light camper. A philosophical approach to the issue helps with the frustration, because there is no alternative.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 07-16-2013, 03:16 PM   #17
Rockwood Premier A126
gregory's Avatar
I read your post to Gary and he has raised a couple of good points for your consideration.
Let's revisit the cabinet de-lam issue. The coolcat thermostat is mounted on that cabinet. There is also the wheel well is located under the cabinet.
It could be moisture from microwave use or a leak in the wheel well or other moisture getting in there that has not only messed up the cabinet has also corroded a wire or connection for the thermostat. Something is going on that may connect the two issues.
If it was ours, we'd take pics of our own, a lot of them. Then, in order to continue comfortably enjoy the rest of the trip, Gary'd replace the thermostat. While we're at it, a look inside the cabinet behind the microwave and take a bunch of pics of what is found in there as well.
But then, ours is out of warranty...
Sorry for your troubles and best of luck,
Deb
Deb & Gary
2007 Ford E150 cargo van, 2012 Rockwood Premier A126
Everybody needs beauty as well as bread, places to play in and pray in, where Nature may heal and cheer and give strength to body and soul alike._ John Muir
gregory is offline   Reply With Quote
Old 07-16-2013, 04:04 PM   #18
im not sure about the delamination .. but i did have the microwave cabinet pull away from the interior side of the camper ... i also believe our buddy hamguy had the same issue.
For us .. it was a simple matter of taking it in .. having them re-screw the cabinet to the wall and that was it ... dont do it yourself as there are strict tolerances in the amount of screw depth that you can go .. before you pierce the outside shell.
if the counter top is delaminating .... then the issue could be water coming in from the outside handrail, light socket, or 120 power socket ...
my main note for you is ... that the cabinet is a support for the outside wall. when you put up your trailer .. it will not allow you to align the top triangle side with the box .. and if you force it ... you may break the sealing plastic strip along the bottom end of the triangle.
sorry cannot help you with the cool cat .. however you should never turn the cooling on then ramp it over to heat within a short time-frame ... as this will cause a definate failure .. i read this information in the coolcat manual that came with the camper ..
keep us updated .. d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 07-16-2013, 06:02 PM   #19
Mostly Harmless
thehamguy1's Avatar
Does your camper get really hot inside when it's closed up, Jim? If it does I'm going to once more plant my foot firmly in my mouth by speculating that excessive heat buildup could cause both the trim and the Formica to let go of their attachment. When I was doing remodeling work one of the easiest ways to remove Formica was to heat it with a clothes iron. It didn't even have to be at its hottest setting to soften the contact cement used to fasten it on. It was the work of seconds to heat an area and slip a putty knife under the edge to remove it. As the edge banding may also be held in its edge groove with contact cement, that could be softening too.
It's quite possible that the sink top and the microwave cabinet top were not made at the same time or with the same batch of glue. I'm guessing something went wrong with either the glue itself or with the application method on that top. If it's glue failure and not moisture buildup, that would be the better outcome, I think, and much easier to fix.
Just chipping in with my $.02 worth. When I'm proven wrong once again, let's all pretend I never mentioned it.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 07-16-2013, 11:16 PM   #20
handbuilder's Avatar
For what its worth - the ceiling fan(at least mine) can suck hot air out or bring outside air in....so that might help to draw out the heat. When I first used the cool cat, I had to get used to the delay in it shutting off. The furnace took a good half hour of learning how it operated in shutting off...didnt have the instruction manual with me - but once I determined to be patient in operating the cool cat and waiting for the cycling, it wasnt as irritating. My expectations kept comparing to the instant operational result like our stick built home offers but the unit in the trailer is much different in the delay to start and stop - has to finish its cycle and then shut off. Also it took many attempts to figure out how to actually shut it off - having to watch the digital light to the "off" mode...I unknowingly kept pushing the mode back to "on" thinking I was "off". haha
Another thought that comes to mind is the temperature you have your cool cat set to? Is it possible its not shutting off because its working to achieve the cool down temp you have it set at?
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
