11-16-2016, 06:36 PM
#21
Originally Posted by johnbryanpeters
Don't run it on DC - it uses a lot of current. Mine uses 11 Amperes nominal.
Is it an issue while driving though with a decent alternator? I am upgrading truck and am thinking about getting the 220 Alternator option.
2017.5 Rockwood Ultra Lite 2905WS (all the options)
New TV- 2017 Ram 3500 SRW Sport 4X4
Old TV- 2007 Dodge Ram 1500 Sport (Hemi)- towing vehicle
11-16-2016, 06:55 PM
#22
Georgia Rally Coordinator
I have always ordered my trucks with the 220 alternator and never have any issues with Frig. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
11-16-2016, 07:46 PM
#23
Ok, so after reading this, and not having my trailer yet until December, does my new Rockwood Ultra Lite have a 3 way or a 2 way fridge? Would love to run it on DC if i can while driving. Propane is not cheap out in SO Cal.
It's a 2 way fridge.
Generally, 3 way fridges are only found in popups, A-frames and truck campers.
Nearly all full size TTs, 5th wheels and motorhomes have 2 way fridges. Some have residential fridges.
3 way fridges are much smaller and have no freezer, just an ice tray. Since they have much less cubic feet to cool, 12v DC power can maintain the temp.
11-16-2016, 08:00 PM
#24
Got it. thanks again for the info. i am totally new to all this, and it makes it harder, because i haven't even gotten my trailer yet...lol
11-16-2016, 08:12 PM
#25
In some longer tunnels it is illegal to go through operating a propane appliance. It's a safety issue.
2017 A212HW
2016 Ford Explorer TV
The Villages, Florida
2019 Puma 255RKS 5th Wheel
2013 Ford F-150 w/ max tow
11-16-2016, 09:07 PM
#26
As well as a number of tunnels where camping trailer are restricted altogether because of the propane bottles.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
11-16-2016, 11:12 PM
#27
2017 A212HW
I've only seen this once, on the east coast where most everything is illegal but unenforceable
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
11-17-2016, 07:16 AM
#28
Ignitor Button
Originally Posted by JArry
I have actually found that simply holding in the igniter button for a few seconds after the successful ignition tends to keep the flame going. I don't know why - maybe the button is somehow connected to the gas flow? Or maybe it's just coincidence.
There is a thermocouple in the flame, it tells the gas valve that there is flame. If you were to quickly ignite, then release the button, the gas would shut off as a safety feature. If you hold the button down, it bypasses the thermocouple until it is heated a bit. Once there is enough heat, the thermocouple tells the gas it's okay to keep flowing.
If you start your fridge, then turn it off, if you listen carefully, you might hear the gas shut-off make a tiny click. It usually takes about 30 seconds when I play with it. That's the thermocouple telling the gas valve there is no flame.
As a side note, we have had the flame blow out during very windy weather, the gas will continue to flow and it generally sets off our propane alarm. At least that's my theory. I also have it blow out while we are towing, so now I use the 12v while driving.
Mark
Michigan
2014 a122s
2014 Tacoma Double Cab
My YouTube Channel
Days Camped 2016/2017/2018/2019: 98/106/109/73
11-17-2016, 08:58 AM
#29
194'er
My 3 way has a freezer
2015 rockwood 194A HW.
11-17-2016, 09:03 AM
#30
As does the Dometic RM8501 in my R-Pod RPT-171.
11-17-2016, 09:13 AM
#31
Hey Dan...
My Dometic 3 way in my TC has a freezer... In fact, in the hard sided Palomino TC's you can opt for a double door 3 way with separate freezer and ice maker and or a compressor fridge.
IMO, the absolute best way to increase the efficiency of any absorbtion refrigerator is to add an exhaust fan (or fans) in the upper vent area and duct the airflow across the upper external condenser.
11-17-2016, 09:27 AM
#32
If as you stated "all the options " you have a 2 way frig! Unless they / You install a "Residential "! Youroo! !
11-18-2016, 01:00 PM
#33
Ahh, that makes sense. Thanks! Maybe this is explained in the instructions and I never read them, thinking I knew what I was doing.
For the record, I also run it on 12V while driving because I never had a reason not to, and because the dealer told me, probably falsely, that it is illegal to run on propane in MI while moving/driving.
Former owner of 2016 Flagstaff T12RBST A-Frame - we had a good run, but it's time for a conventional TT!
Nights camped since 2016: 370
11-18-2016, 01:24 PM
#34
The thermocouple is connected to the gas valve "switch" - the one that says on and off. Pushing in this switch while lighting bypasses the thermocouple. For the reasons already given, that switch should continue to be pushed in for 30 seconds after lighting the fridge.
The igniter is a one push peizio igniter to create a spark at the fridge burner (very similar to many lower end propane grills). It creates one spark per push of the button. That is why is recommended to push the igniter button immediately after a "poof" where the flame blows itself out (not uncommon at high altitude). Because the flame blew itself out, there is residual gas at the burner that will readily light if another spark is created right away.
Since I learned this trick, I have had very few problems starting the fridge (usually 2 quick pushes of the igniter with a "poof" on the 1st push) at altitudes from 6,000 - 8,000 ft (we haven't camped higher yet).
Our fridge will blow out while driving - I tried it twice on a 6 hour drive from Panhandle Texas to Colorado Springs. So I use DC while towing. I did check, and I am seeing 13.2 to 13.7 volts at the camper with fridge on DC, and running lights on with tow vehicle running. So I am satisfied that I will not run my camper batteries down while towing with fridge on DC. But not all tow vehicles have wiring as robust as mine. And I did change out the camper tail lights for LEDs (another 1.2 amp reduction). Eventually, I will change all the running lights out for LEDs.
Fred W
2014 Rockwood A122 A-frame
11-18-2016, 09:35 PM
#35
Now I'm confused. Above I was referring to continuing to hold down the igniter (piezo) button/plunger after the spark - NOT the gas valve knob/button, which I had already been holding down (turned to the full open ignition position). So is the piezo igniter connected to anything else, or is it an entirely self-contained mechanism? As I said earlier, it may have just been coincidence that holding the igniter down seemed to have some effect.
11-21-2016, 01:14 PM
#36
In this case, I think it would be a co-inky-dink. The piezo just fires one shot and it's done. It's self-contained. In fact, I cannibalized an old camp stove and took the ignitors out and put them in the three-burner range inside the trailer!
One last note, here's what my flame looks like when it's working properly:
http://www.forestriverforums.com/for...up-119763.html
I had a problem with some soot and could never find our what a good flame was supposed to look like.
Cheers!
Mark
Michigan
2014 a122s
My YouTube Channel
