If they are still using the same thermostat as my A Frame, read the manual and you can set it for 1 degree differential, the default is 2 degree. It will help some. I also took the thermostat apart and the thermister was laying on the case. I also made the hole around the thermister bigger.
I think the area of the A frame is so small and the heater so large, it just take time for the thermostat to catch up.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
